Missing Login Screen
    I installed a login screen from within settings and applied it but it does not show up when I boot my computer. All I get is a generic purple login screen. My splash screen and themes are just fine. I also applied one of the default login screens like Breeze to see if it was just the one I installed, but I got the same results. I do not really know what is going on or how to fix it. Will someone please help me? This is on Kubuntu 20.4. Not sure what other information you need but I can provide other details.
    Which login screen did you install?
      To point out the obvious, just in case:
      Did you select the installed screen? Installing itself doesn't select it.
