libc has been retained
    [SOLVED] libc has been retained
    Hi
    I was trying to upgrade from 19.10 and used:
    sudo do-release-upgrade -m desktop
    And appeared "No new release found."
    The same with
    pkexec do-release-upgrade -m desktop -f DistUpgradeViewKDE
    So, I used
    And upgraded without problems, but now...
    sudo apt upgrade
    Leyendo lista de paquetes... Hecho
    Creando árbol de dependencias
    Leyendo la información de estado... Hecho
    Calculando la actualización... Hecho
    Los siguientes paquetes se han retenido:
    libc++1
    0 actualizados, 0 nuevos se instalarán, 0 para eliminar y 1 no actualizados.
    sudo apt dist-upgrade
    libc++1
    - How could I fix that?
    - Is there any way to change to 20.04 LTS and leave Development release?
    Thanks
    use apt properly :
    sudo apt update
    sudo apt full-upgrade
    See if this fixes it.
    Though this is somewhat common, and OK. I think this means that there may be other things are still coming that libc++1 needs before it will be updated. You are safe.
    You are no longer in a development state.
      Hi, thanks for the answer.
      Libc++1 still retained, I'll wait for the "other things" and see if finally upgrades.
      How do I know if I'm in development state?
      Regards
