I have two notebooks with the above mentioned problem, one is a Sony Vaio VPCS11B7E, the other a Lenovo T520.
On both systems I have the possibility to run Kubuntu 18.04 or 20.04 by switching with grub bootmanager.
The hardware I need to use with NAVIT car navigation system is a USB GPS mouse with U-BLOX chip.
The GPS mouse is detected in all cases: with lsusb I get
martin@VAIOMB:~$ lsusb
Bus 002 Device 006: ID 1546:01a8 U-Blox AG [u-blox 8]
There is no problem to use the gps mouse with Kubuntu 18.04, it is running with cgps, xgps and can be used in NAVIT.
The problems start with Kubuntu 20.04 where I still get the above mentioned answer from lsusb. But what is working in Kubuntu 18.04
- when I connect the gps mouse to the notebook it is recognized and gpsd is started in the background - is not working in Kubuntu 20.04.
What I found is that with both versions of Kubuntu the gps mouse is working: when I start
martin@VAIOMB:~$ gpsmon /dev/ttyACM0 the mouse is responding like this:
VAIOMB:/dev/ttyACM0 9600 8N1 NMEA0183>
│Time: 2021-05-22T12:03:30.000Z Lat: 52 14.481810' N Lon: 8 48.437560' E │
└───────────────────────────────── Cooked TPV ─────────────────────────────────┘
│ GNRMC GNVTG GNGGA GNGSA GPGSV GLGSV GNGLL │
└───────────────────────────────── Sentences ──────────────────────────────────┘
│PRN Az El S/N ││Time: 120330.00 ││Time: 120330.00 │
│ 5 45 21 0 ││Latitude: 5214.48181 N ││Latitude: 5214.48181 │
│ 9 319 0 0 ││Longitude: 00848.43756 E ││Longitude: 00848.43756 │
│ 16 298 51 38 ││Speed: 0.125 ││Altitude: 116.5 │
│ 18 134 72 0 ││Course: ││Quality: 1 Sats: 08 │
│ 20 69 32 0 ││Status: A FAA: A ││HDOP: 1.39 │
│ 23 145 16 0 ││MagVar: ││Geoid: 46.1 │
│ 25 137 3 0 │└─────────── RMC ────────────┘└─────────── GGA ────────────┘
│ 26 254 72 37 │┌────────────────────────────┐┌────────────────── ──────────┐
│ 27 269 19 35 ││Mode: A3 Sats: 16 26 27 31 ││UTC: RMS: │
│ 29 79 36 18 ││DOP: H=1.39 V=1.41 P=1.98 ││MAJ: MIN: │
│ 31 211 21 23 ││TOFF: 0.034503324 ││ORI: LAT: │
│ 69 12 15 11 ││PPS: N/A ││LON: ALT: │
└────── GSV ───────┘└──────── GSA + PPS ─────────┘└─────────── GST ────────────┘
(50) $GNGSA,A,3,76,77,87,69,,,,,,,,,1.98,1.39,1.41*12
(64) $GPGSV,3,1,11,05,21,045,,09,00,319,,16,51,298,38,1 8,72,134,*7F
(64) $GPGSV,3,2,11,20,32,069,,23,16,145,,25,03,137,,26, 72,254,37*75
(57) $GPGSV,3,3,11,27,19,269,35,29,36,079,17,31,21,211, 22*4A
(66) $GLGSV,3,1,09,69,15,012,10,70,16,071,,75,10,168,,7 6,58,201,19*6A
(64) $GLGSV,3,2,09,77,50,309,21,78,03,334,,85,30,050,,8 6,78,004,*67
(31) $GLGSV,3,3,09,87,27,243,41*56
(52) $GNGLL,5214.48180,N,00848.43731,E,120329.00,A,A*7D
(68) $GNRMC,120330.00,A,5214.48181,N,00848.43756,E,0.12 5,,220521,,,A*6C
(35) $GNVTG,,T,,M,0.125,N,0.231,K,A*3B
(75) $GNGGA,120330.00,5214.48181,N,00848.43756,E,1,08,1 .39,116.5,M,46.1,M,,*43
(50) $GNGSA,A,3,26,16,31,27,,,,,,,,,1.98,1.39,1.41*17
(57) $GPGSV,3,3,11,27,19,269,35,29,36,079,18,31,21,211, 23*44
(66) $GLGSV,3,1,09,69,15,012,11,70,16,071,,75,10,168,,7 6,58,201,19*6B
(52) $GNGLL,5214.48181,N,00848.43756,E,120330.00,A,A*75
When I check syslog with
- unconnected gps mouse
- start "tail -f /var/log/syslog"
- then connect the gps mouse
I find differing situations:
with Kubuntu 18.04 I get
May 22 11:12:24 VAIOMB kernel: [ 459.645801] usb 2-1.1: new full-speed USB device number 4 using ehci-pci
May 22 11:12:24 VAIOMB kernel: [ 459.755304] usb 2-1.1: New USB device found, idVendor=1546, idProduct=01a8, bcdDevice= 3.01
May 22 11:12:24 VAIOMB kernel: [ 459.755310] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 22 11:12:24 VAIOMB kernel: [ 459.755314] usb 2-1.1: Product: u-blox GNSS receiver
May 22 11:12:24 VAIOMB kernel: [ 459.755318] usb 2-1.1: Manufacturer: u-blox AG - www.u-blox.com
May 22 11:12:24 VAIOMB kernel: [ 459.755862] cdc_acm 2-1.1:1.0: ttyACM0: USB ACM device
May 22 11:12:24 VAIOMB mtp-probe: checking bus 2, device 4: "/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1"
May 22 11:12:24 VAIOMB mtp-probe: bus: 2, device: 4 was not an MTP device
May 22 11:12:24 VAIOMB upowerd[858]: unhandled action 'bind' on /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1
May 22 11:12:25 VAIOMB upowerd[858]: unhandled action 'bind' on /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0
May 22 11:12:25 VAIOMB systemd[1]: Starting Manage ttyACM0 for GPS daemon...
May 22 11:12:25 VAIOMB gpsdctl: gpsd_control(action=add, arg=/dev/ttyACM0)
May 22 11:12:25 VAIOMB gpsdctl: reached a running gpsd
May 22 11:12:25 VAIOMB systemd[1]: Started Manage ttyACM0 for GPS daemon.
May 22 11:12:35 VAIOMB ModemManager[674]: <info> [device /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1] creating modem with plugin 'u-blox' and '1' ports
May 22 11:12:35 VAIOMB ModemManager[674]: <warn> Could not grab port (tty/ttyACM0): 'Cannot add port 'tty/ttyACM0', unhandled serial type'
May 22 11:12:35 VAIOMB ModemManager[674]: <warn> Couldn't create modem for device '/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1': Failed to find primary AT port
Remember: the gps mouse is usable in this situation !!!
With Kubuntu 20.04 I get
May 22 11:22:58 VAIOMB kernel: [ 295.096705] usb 2-1.1: new full-speed USB device number 4 using ehci-pci
May 22 11:22:58 VAIOMB kernel: [ 295.206226] usb 2-1.1: New USB device found, idVendor=1546, idProduct=01a8, bcdDevice= 3.01
May 22 11:22:58 VAIOMB kernel: [ 295.206232] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 22 11:22:58 VAIOMB kernel: [ 295.206235] usb 2-1.1: Product: u-blox GNSS receiver
May 22 11:22:58 VAIOMB kernel: [ 295.206239] usb 2-1.1: Manufacturer: u-blox AG - www.u-blox.com
May 22 11:22:58 VAIOMB kernel: [ 295.207152] cdc_acm 2-1.1:1.0: ttyACM0: USB ACM device
May 22 11:22:58 VAIOMB mtp-probe: checking bus 2, device 4: "/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1"
May 22 11:22:58 VAIOMB mtp-probe: bus: 2, device: 4 was not an MTP device
May 22 11:22:58 VAIOMB systemd[1]: Starting Manage ttyACM0 for GPS daemon...
May 22 11:22:58 VAIOMB systemd[1]: Finished Manage ttyACM0 for GPS daemon.
May 22 11:23:01 VAIOMB ModemManager[711]: <info> Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1': not supported by any plugin
Remember: the gps mouse here is not usable.
The important difference is one line under Kubuntu 18.04 reporting => creating modem with plugin 'u-blox' and '1' ports <=
and the corresponding line under Kubuntu 20.04 is reporting => Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1': not supported by any plugin <=
This under Kubuntu 18.04 leads to the normal situation that gpsd is started in the background and can gather input from the gps mouse and deliver it to NAVIT.
Under 20.04 gpsd is NOT started when the gps mouse is connected but started with NAVIT but without connection to the gps mouse and can NOT work.
So the question is: what is the difference for the modemmanager between 18.04 and 20.04?
Where and how can I get and install the modem plugin for u-blox devices, that in 18.04 is existing although I didn't install it?
One thing in addition: to me it looks like this is NOT a Kubuntu but a Ubuntu problem because automated udev recognition and things like modem plugins do not come from Kubuntu. Maybe I will add the same thread in a Ubuntu forum.
Anyway: can someone please help with this?
Thanks in advance!
Thanks in advance!
