Hi
I installed Kubuntu on my surface Go 2. I must say I'm really happy with it, and it works way better than Windows 10, providing an almost Macbook-like experience with command line at hand. Congrats for this.
I'm running into some trouble with tap-to-click functionality. I don't want it because it goes in the way constantly. Activating/deactivating it in the touchpad section of the config app worked fine and has suddenly stopped working. this after I installed Crossover, Dosbox, Discord, Slack : dunno if it has anything to do.
I tried to add the line Option "Tapping" "False" in the touchpad section of /usr/share/X11/xorg.conf.d/40-lib-input.conf and it worked for a while (the tapping options in the config app were grayed out). Then the tap-to click came back, while the line is still present and the option in config app now available again, but doesn't do anything.
Any ideas or help would be appreciated. Thanks!
PR
PR
