Suspend using deep sleep mode causes full shutdown / possible premature power cut
    [System] Suspend using deep sleep mode causes full shutdown / possible premature power cut
    Sometime within the last week or so I realized that my PC was cold booting when I had previously put it to sleep. I can't pinpoint exactly when it started, but now every suspend attempt results in a hard shutdown, specifically when using the deep sleep mode (not s2idle). I also suspect intentional shutdowns aren't happening cleanly. Normally the LED on my motherboard will go out with a shutdown but it's staying on, which is what usually happens when it suddenly loses and then regains power.
    After some searching online, I tried various things to try to diagnose the problem but have come up empty.
    Has anyone run into this issue and/or know of a workaround?
    PC Details
    • CPU: AMD Ryzen 7 7700X
    • GPU: NVIDIA GeForce RTX 4070, drivers: nvidia-driver-595-open (595.99.02)
    • Motherboard: ASrock B650E PG Riptide WiFi, firmware: v4.43
    • OS: Kubuntu 26.04.1 (upgraded from 24.04 in early October, suspend functional after upgrade until recently)
    • Kernel: 7.0.0-44
    Notes
    • The journal logs cut cut off abruptly after "kernel: PM: suspend entry (deep)".
    • Google suggested that there might be an issue with the nvidia drivers. Tried changing the configuration in modprobe.d, specifically NVreg_UseKernelSuspendNotifiers=1, but this did not help.
    • Tested systemctl suspend with the full range of stages in /sys/power/pm_test. No power loss / shutdown occurred until setting pm_test back to none.
    • Apt history showed that the issues roughly coincided with a recent upgrade to kernel 7.0.0-44, so on boot I used the grub menu to boot with kernel 7.0.0-43. At first I was able to suspend normally (repeatedly) and thought I had found the issue but then then the next day the problem resumed while still using 7.0.0-43 and I have not been able to replicate the successful suspend.
    • I had not changed any BIOS settings prior to this problem starting. I tried adjusting a few based on some search results but none seemed to improve anything.
    • I also tried updating to the latest non-beta BIOS release for my motherboard since I was previously running an older version, but there was no improvement.
    • I currently have MemorySleepMode=s2idle via a drop-in config in /etc/systemd/sleep.conf.d, and that is working to avoid the shutdowns from deep suspend for the time being, but I want to get deep sleep mode working as before.
There is 1 user viewing this topic.
