behavior is not working with usb drives - writing to usb is not accurate, and "early" eject produce hard locked system
    [Software] behavior is not working with usb drives - writing to usb is not accurate, and "early" eject produce hard locked system
    i'm on a test install in 26.04, just upgraded to 26.04.1 and writing a file to a usb drive.
    the file is the 4.8gb 26.04.1 iso image.
    coming from 24.04, the behavior seemed to be the same broken behavior in 26.04 that 24.04 had - all files sent to the usb "buffer" count as moved files, whether the file write operation on the usb drive is actually finished or not. 26.04 said the 4.8gb iso file "moved" to the usb drive in 20 seconds - which is total lie, but that is the same lie that 24.04 told.
    the difference is that in 24.04, when the usb drive is "safely removed", the remove icon spins and spins until the entire file write is complete on the usb drive.
    i don't know what happened in 26.04, but after waiting a couple minutes after the pop said "moving finished" (or copy finished, same principle), i clicked to "safely remove" the usb drive.
    the entire system locked up. hard lock. almost immediately after clicking safely remove. could this be a hardware issue? maybe, but earlier today in 24.04 the exact same sequence when writing 26.10 to the usb drive worked perfectly.
    i didn't think i would ever say this, but i am going to have to start looking for alternate distros now. i've been on kde for over 20 years, and on kubuntu almost since the beginning, with kde 3.
    i love the look and feel of kde and have installed on so many machines over the years, work, friends, family, but now the issues are just becoming more than i want to work on.
    tips: fix the usb write file bug - in windows the file transfer actually shows write speed and when the write popup disappears, the usb drive can be ejected immediately. this is the expected behavior. why the copy/write popup goes away after mere seconds for huge files is a lie.
    no idea why the computer hard locked. i waited 10 minutes to see if the write finished internally on the usb, which might allow 26.04 to unfreeze, but even after 10 minutes it was no go. why should the simple action of clicking to remove the external usb cause a hard lock? definitely not a behavior that i have ever seen in 24.04, and i've done a lot of ejecting after the popup said "finished", but the usb was nowhere near finished writing. same machine. so many files over the last month even.
    is there something in 26.04 that would demand more of the hardware?
    Operating System: Kubuntu 26.04 LTS
    KDE Plasma Version: 6.6.6
    KDE Frameworks Version: 6.24.0
    Qt Version: 6.10.2
    Kernel Version: 7.0.0-38-generic (64-bit)
    Graphics Platform: Wayland
    Processors: 12 × 12th Gen Intel® Core™ i5-12400F
    Memory: 32 GiB of RAM (31.2 GiB usable)​
    AI Overview
    When you click Safely Remove (or Eject) on a mounted USB drive in Ubuntu Linux while a write operation is still underway, several distinct actions and consequences occur:
    What Ubuntu Tries to Do
    • Waits for Pending Cache Flush: Clicking eject/safely remove instructs the operating system to finish and flush all pending write operations from RAM (the kernel write cache) to the physical flash memory of the USB drive. [1, 2, 3]
    • Blocks or Queues: Depending on the file manager or desktop environment (GNOME, KDE, etc.), the system will often block the removal and wait until the cache is completely written before unmounting and powering down the port. If you physically pull the drive out while it is still trying to flush or finish, bad things happen.
    What Happens if You Physically Pull It Too Early (Interrupted Write)
    • Incomplete File Transfers: The file or data currently being written will be truncated, missing, or filled with zeros/garbage data.
    • File System Corruption: If the operating system was in the middle of updating file allocation tables, directory structures, or journaling data, the entire file system (e.g., FAT32, NTFS, ext4) can become corrupted, making the drive unreadable or throwing "Access Denied" / "RAW format" errors. [1, 2, 3]
    • Data Loss on Related Files: Caching groups multiple write operations together. Interrupting it can damage more than just the file you actively dragged over.
    Slava Ukraini! 🇺🇦
      Thanks for the reply.
      the issue is that kubuntu says the write operation is done. but it really isn't. the usb3 drives can have large buffers that somehow trick kubuntu into thinking the write operation is done, and only when clicking the "safely remove" icon, then kubuntu recognizes the drive cannot be removed.
      in 24.04, the little up arrow changes into a spinning wheel for up to 2 minutes or so as the write operation is finished. in 26.04 - the entire system crashed, requiring a hard power down. no idea why this happened, and while i don't think the other files on the usb were affected, it's probably not the best idea to do it again.
        For the upcoming future:
        https://blogs.kde.org/2026/10/27/fix...k-filesystems/
        I see a spinny icon on the desktop widget when using the standard "safely remove" option here in 26.04, and later Plasma versions.
        I also see the spinny icon in Dolphin
ID:	694989​Click image for larger version
        It is still spinning using a old-ish and definitely sl-l-l-o-o-w USB stick I just copied 14Gb of video files to. It is formatted with NTFS for this test.
        I suspect something else may be at play here for you. I am working with a lot of external drives right now on my lower-spec Kubuntu 26.04 system, including a number of old to ancient spinny-rust HDDs and am constantly removing drives and USB sticks, with not a single issue. I can see a heavy write/transfer action spiking the CPU at least a little, so heat might be a thing to look at. My tiny and barely ventes system does ramp up the fan when doing long copy sessions, and ite CPU does heat up, but not alarmingly.
          In a related way, quite awhile ago, I grew to severely dislike the "Safely Remove" option in the system tray because it ejects the USB device requiring you to unplug the device and plug it back in again to use it again - ridiculous IMO. So I wrote a "Unmount" solid action so I can unmount rather than eject a USB device. Still requires you to wait for the transfer to complete before it works, but I can re-mount it without pulling it out and plugging back in.
          I do like the idea of a swirling arrow to clearly indicate a transfer in progress.
            ANY action that is happening currently/in the background should have an activity indicator for the user. Any action that does not is poorly written IMO.
            Slava Ukraini! 🇺🇦
