Upgrade to 26.04 from 24.04 caused problems in Dolphin
    [Software] Upgrade to 26.04 from 24.04 caused problems in Dolphin
    I had several folders shared on my Windows 11 machine linked in the Remote section of Dolphin. After the update to t0 26.04 these did not work. It keeps asking for the password and failing to connect.
    After trying many things, these mostly work now. However, Dolphin continues to fall back to "can not connect, path does not exist, etc" when I click on one. If I click on one and it doesn't work but another does work, the first one suddenly works again. Then, I click on another, or sometimes the same one, and none of the links to folder on the Windows 11 machine work.
    Same behaviour, roughly, with RDP connect to the Windows 11 machine. Sometimes it works and sometimes it refuses to work.
