Hello everyone! Happy new LTS release! 🎂🥳
I am thinking of installing kubuntu 26.04 on my laptop, as well as Vanilla OS 2 Orchid, along with the existing win11. I would like to ask for partitioning advice prior installation.
I have installed a 1TB m2 drive to the laptop, cloned the old drive´s partitions with clonezilla and now I have plenty of unallocated space left, around 800GB I think. The windows partitions take up less than 200GB and I am not planning to store data or install any software there.
My current wish is to be able to run all operating systems on my laptop, and hopefully be able to upgrade to kubuntu 28.04 LTS without the system breaking in about two years.
A blog in the vanilla OS website suggests the following for manual partitioning:
I had a chat with an AI tool which gave me the below suggestion:
So, my question is, do the above make sense? Is there by chance a different recommended method for manually partitioning before installing multi boot with 2 linux distros + windows?
Thank you in advance!
References:
- GPT table
- 1GB for /Boot (ext4)
- 512MB for /EFI (fat32)
- 20.5GB ¨for the Root partition pool unformatted.¨, which I do not understand what it means,
- swap for hibernation support
- remaining storage for /var (btrfs)
- leave everything windows related as-is
- 80GB for Kubuntu root (ext4 or btrfs), mount point /
- 80GB for Orchid root (ext4 or btrfs), mount point /
- 24GB linux swap, shared between Kubuntu and Vanilla
- remaining GB for storage, accessible via all three operating systems. (ntfs)
- install Vanilla, then Kubuntu so I keep the Kubuntu boot loader.
- ¨Use the existing ESP for all bootloaders; do not create a new ESP.¨
- ¨Add the NTFS partition to each OS /etc/fstab using UUID: sudo blkid to get UUID, then mount with ntfs-3g options for Linux.¨
References:
- https://vanillaos.org/blog/article/2...-devlog-22-nov
- chat gpt5-mini output, on 25 Apr 2026
