Anything added to Dolphin? System Settings? System Monitor? Any changes?
    [Post-Install] Anything added to Dolphin? System Settings? System Monitor? Any changes?
    This might be a stupid question but I think some of the core components of an OS is the file manager, the System Settings, the task manager.
    Have any changes been made to Dolphin, System Settings, System Monitor?
    There is also the issue of enabling the Numlock during boot. That seems to be a feature that is universally ignored on all Linux distros.
    Yes, and........?
    There are always changes, tweaks, etc. Are you looking for specific changelogs?
    https://kubuntu.org/news/kubuntu-25-...ffin-released/
    https://kde.org/announcements/plasma/6/6.3.0/
    https://kde.org/announcements/plasma/6/6.3.4/
    https://kde.org/announcements/gear/24.12.0/
    https://kde.org/announcements/changelogs/gear/24.12.3/
      In Dolphin, if I have a set of files named
      saa
      sab
      sac
      saz
      If I select file saa and I press on “s” on the keyboard, it jumps to the next file.
      This is a nice way to jump forward.
      If I use the mouse to select sag and I press “s” again, it does not jump to sah, it jumps backwards to saa or something like that.
      Also, someone had ask for the ability to position icons. I think this is for Icon view mode.
      We had asked for the ability to show KB, MB, GB, TB where 1024 B = 1 KB. They added this ability. It works fine in Dolphin and during file copy and in Discover.
      It does not work in System Monitor where it shows as KiB, MiB, GiB, TiB.
      For the System Monitor, I was hoping some changes would be made for it to be more like Windows. Separate info for the CPU core (the usage). Some info about the cache sizes, the RAM type and such technical details.
      Other than that, there doesn’t seem to be visible changes.
