adept problem after upgrading to Jaunty
    Try to run Adept then get this message:
    It seems that the recovery has failed. Please fix manually (try dpkg --configure -a and/or apt-get -f install) in terminal...
    The error was:
    APT Error. Context:
    Running dpkg,
    [ /usr/bin/dpkg, --status-fd, 3, --configure, -a ],
    Sup-process returned error code 2,
    Error processing linux-image-2.6.28-11-generic : subprocess post-installation script returned error exit status 2.,
    Error processing linux-image-generic : dependency problems - leaving unconfigured.,
    Error processing linux-generic : dependency problems - leaving unconfigured.,
    Error processing linux-restricted-modules-2.6.28-11-generic : dependency problems - leaving unconfigured.,
    Error processing linux-restricted-modules-generic : dependency problems - leaving unconfigured.
    Can't load further updates, thinks adept still running...have tried 'sudo --configure -a' with no luck
    what to do now please?
