I had kubuntu 7.10 and I tried to install kubuntu 8.04 last night but I had some troubles:
my system has a cd reader and a cd burner; when I booted using the installation CD (in the reader), the installation process stopped when it tried to load the kernel.
I saw these errors on the screen:
ata2.01: exception EMask 0x0 SAct 0x0 SErr 0x0 action 0x2 frozen
ata2.01: cmd ...
ata2.01: status: [DRDY ERR]
ata2.01: revalidation failed (errno = -5)
Trying to boot from the cd burner I had no errors, so I went on with all the installation, erasing all my old partitions of the two ide disks and making only a root partition on the first disk (10Gb) and a home & swap partitions on the second one (4GB).
Removing the disc and rebooting, the boot stops when "Loading hardware drivers" with the same errors that I wrote before... looping every 5 seconds.
Pressing ctrl-alt-del I got a login screen (tty) but the FS was mounted ro and I did not manage to understand the problem...
Any idea? Is there any other info I can post to help you in supporting me?
Thanks in advance.
Ciao,
V.
ata2.01: cmd ...
Thanks in advance.
Ciao,
V.
