It's been 2 days and 2 fresh installs. I just cannot seem to get this stupid thing to connect to an access point.
Here is the situation:
I'm dual booting Windows XP and Kubuntu 8.04 Hardy Heron (32bit). XP side the card is working fine. Kubuntu side I can see wireless networks, the manager recognizes my card, and the Bluetooth works perfectly. But when trying to connect it never makes it past 28%. Connecting using iwconfig and dhclient from command line doesn't work either.
Here is what I have tried:
First I tried connecting to different kinds of networks. No dice. WEP, WPA, unprotected. It doesn't matter they all hate me. So first I plugged in a hard line (yes the regular nic works fine.) and downloaded build-essential and all the other absolutely necessary stuff. So then I tried a madwifi install. Then I tried with wpasupplant. After this I tried to fall back on the windows driver using ndiswrapper. None of these worked. I even tried different drivers in ndiswrapper. Nothing. Notta. Not even a change in the way the machine reacted. Every time it was 28% and fail.
Here are the sites I've been looking at:
http://www.jjjennnnn.com/kubuntu87445bu.html
https://help.ubuntu.com/community/Wi...er/Ndiswrapper
http://www.thinkwiki.org/wiki/How_to...xpress_Adapter
http://ubuntuforums.org/showthread.php?t=419348
http://www.thinkwiki.org/wiki/Installing_Ubuntu_6.10_(Edgy_Eft)_on_a_ThinkPad_T6 0
http://forums.fedoraforum.org/showthread.php?t=126266
and a few other madwifi sites I forgot to save.
I know I sound like a lost cause but I really need this stupid laptop to work for school. The school assigned this laptop so it's the one I have to use, but the CS department requires a linux install, that the IT department won't support. Please any help at all is very appreciated! Thank you in advance!
