Sony WALKMAN NWZ-A Series (NWZ-A828) - USB and MTP problems and solutions
    i just bought a sony walkman nwz-a828.
    an amazing player in terms of audio and video quality.
    it really is.
    ipods are crap in comparison.
    anyway...
    this post is because i managed to get it working both via usb and mtp.
    usb is for drag&drop with any file manager.
    mtp is for use with amarok (or similar multimedia app).
    problems
    in normal circumnstances, you'll have huge problems in 8.04 hardy:
    a) device not detected as a usb device (so you can't drag&drop your music)
    b) mtp doesn't see it (so you can't use it with amarok)
    solutions
    you need to enable the source repositories in your package manager.
    for mtp...this is really a short term hack, 'cause libmtp-0.3.0 (libmtp8) already includes this and other devices
    but it's not packed for *ubuntu, yet.
    so..
    sudo -i
    cd /tmp
    become root and go to, for example, /tmp.
    usb issue:
    hal needs to be fixed/recompiled/reinstalled.
    apt-get build-dep hal
    download all the packages that hal needs in order to be rebuilt
    apt-get source hal
    download and unpack the hal source
    nano hal-0.5.11~rc2/hald/util.c
    edit util.c
    at line 201, replace strtol by strtoul
    apt-get source --build hal
    rebuild hal (will automatically compile and build a few deb packages)
    dpkg -i libhal1_0.5.11~rc2-1ubuntu8.2_i386.deb
    dpkg -i hal_0.5.11~rc2-1ubuntu8.2_i386.deb
    dpkg -i libhal-storage1_0.5.11~rc2-1ubuntu8.2_i386.deb
    install the newly created stuff
    mtp issue:
    libmtp needs to be fixed/recompiled/reinstalled.
    /etc/udev/rules/45-libmtp7.rules needs to be updated.
    apt-get build-dep libmtp7
    download all the packages that libmtp needs in order to be rebuilt
    apt-get source libmtp7
    download and unpack the libmtp source
    nano libmtp-0.2.6.1/src/music-players.h
    edit music-players.h
    add the following (braces, commas and all) to the list of sony mp3 players
    { "Sony", 0x054c, "Walkman NWZ-A828", 0x035b, DEVICE_FLAG_UNLOAD_DRIVER },
    apt-get --build source libmtp7
    rebuild libmtp (will automatically compile and build a few deb packages)
    dpkg -i libmtp7_0.2.6.1-2ubuntu1_i386.deb
    dpkg -i mtp-tools_0.2.6.1-2ubuntu1_i386.deb
    nano /etc/udev/rules.d/45-libmtp7.rules
    add the following to the list of sony players
    # Sony Walkman NWZ-A828
    ATTR{idVendor}=="054c", ATTR{idProduct}=="035b", SYMLINK+="libmtp-%k", MODE="660", GROUP="audio"
    reboot and you should be done.
    hth
    gnu/linux is not windoze
    Re: Sony WALKMAN NWZ-A Series (NWZ-A828) - USB and MTP problems and solutions
    My compliments for your solutions and posting!
      hey there im using ubuntu.. i did ur steps and the mp3 finally mounts but for some reason it doesnt let me change the songs i have in it.. it gives me "Error removing file: Read-only file system"
      i tried sudo nautilus /media,,, and it still doesnt work..
      any ideias wht i should change?
        hi.
        the above hacks were carried out on kubuntu 8.04.
        not sure if they work the same for ubuntu (gnome).
        i don't use ubuntu.
        anyway...
        i won't have access to my player till i get back home tonight.
        so i can't try and replicate your problem now.
        but i'll try.
        in the meantime, we can investigate your issue a little bit...
        could you please hook up your player, start a terminal emulator and post the result of:
        id
        to see what groups your user account belongs to.
        there's a few groups you need to be member of, in order for the plug dev things to work.
        cat /etc/fstab
        to see if there's anything funny in your file systems' table
        ls -l /media
        to see if you have any funny mount point in your media directory
        ls -laR /media/path_to_your_player
        to see what the directory tree of your player looks like.
        in particular, who do the files and directories belong to.
        cheers
          well yesterday it worked.. today when i plug in the mp3 it doesnt even mount..im using a sony NWZ-S616F
          i havent changed anything only rebooted my computer.. anyways heres the output
          psychok7@psychok7:~$ id
          uid=1000(psychok7) gid=1000(psychok7) groups=4(adm),20(dialout),24(cdrom),25(floppy),29( audio),30(dip),44(video),46(plugdev),107(fuse),109 (lpadmin),115(admin),125(sambashare),1000(psychok7 )
          psychok7@psychok7:~$ cat /etc/fstab
          proc /proc proc defaults 0 0
          # /dev/sda6
          UUID=1c2d92cd-dae3-4d06-a2c4-01476d82fb71 / ext3 relatime,errors=remount-ro 0 1
          # /dev/sda7
          UUID=35d7964e-820c-4e42-b0ed-5dc8a98915bc none swap sw 0 0
          /dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec,utf8 0 0
          psychok7@psychok7:~$ ls -l /media
          total 24
          drwxrwxrwx 1 root root 8192 2008-09-08 19:10 BACKUP
          lrwxrwxrwx 1 root root 6 2008-07-30 18:48 cdrom -> cdrom0
          drwxr-xr-x 2 root root 4096 2008-07-30 18:48 cdrom0
          drwxrwxrwx 1 root root 4096 2008-09-07 17:42 disk
          drwxrwxrwx 1 root root 8192 2008-09-07 13:31 EXTERNAL HDD
          but the last line i didnt do because the mp3 is not mounting anymore
            well, the NWZ-S616F is not the NWZ-A828.
            they're two different players.
            they're even two different generations.
            the mtp tweak won't work for your player.
            the S616F's got a different product id.
            plus, hardy should already include mtp support for it.
            it lists the S615F and the S618F, so yours should work too.
            and if it doesn't, then we need to find out its actual product id.
            i'd suggest you put things back as they were.
            remove the modified libmtp packages.
            and re-install the standard ones from the repos.
            as for UMS (USB Mass Storage) mode, i'm not sure.
            does your player support UMS?
            if it does, is it at least seen as a new device when you plug it in?
            i'd suggest to remove the tweaked hal packages.
            and put back the original ones from the repos.
            then reboot, plug in your player and issue:
            sudo lsusb
            sudo is possibly superfluous
              mine suports ums and mtp.. it did work on ubuntu 7.10, so how about me checking all those details in from the ubuntu 7.10 live cd, the id and product details ? does it help?
              if not ill just do wht u suggested
                psychok7@psychok7:~$ sudo lsusb
                Bus 005 Device 009: ID 054c:0327 Sony Corp.
                Bus 005 Device 007: ID 09da:0006 A4 Tech Co., Ltd Optical Mouse WOP-35 / Trust 450L Optical Mouse
                Bus 005 Device 004: ID 043d:00bb Lexmark International, Inc.
                Bus 005 Device 003: ID 059f:0c41 LaCie, Ltd
                Bus 005 Device 002: ID 05e3:0606 Genesys Logic, Inc. D-Link DUB-H4 USB 2.0 Hub
                Bus 005 Device 001: ID 0000:0000
                Bus 004 Device 001: ID 0000:0000
                Bus 003 Device 001: ID 0000:0000
                Bus 002 Device 001: ID 0000:0000
                Bus 001 Device 001: ID 0000:0000
                this is the output i got..i havent unistalled those libraries yet thou...oh and i must tell u.. i did follow ur inital instructions but when the time came to modify those documents.. i didnt because i was hoping the models that were listed were enough the S615f/S618f i think its this models.. i didnt put in ur model
                  alright.
                  i see.
                  the device is detected alright...
                  vendor id is: 054c (i.e. Sony)
                  product id is: 0327 (which is actually the same as the S615F and S618F models)
                  so i think the problem is in hal somewhere.
                  possibly in some file here:
                  /usr/share/hal/fdi/information/...
                  could be
                  /usr/share/hal/fdi/information/10freedesktop/10-usb-music-players.fdi
                  don't really know, though...
                  you could do what i did: go back to 7.10 (cfr this).
                  for me, kubuntu 7.10 was rock solid.
                  kubuntu 8.04 is a mess.
                    Jankushka, you are a lifesaver!! I bought this unit last Friday and was five minutes away from returning it because Xubuntu 8.04 wouldn't see it, even if I mounted it using pmount.
                    I followed your instructions to the letter (well, almost - I used vim rather than nano!) and I'm transferring music to my player as we speak.
                    Note, I didn't have to do the very last step b/c after following the prior ones, the applicable lines were already in 45-libmtp7.rules
                    Stellar! Thanks. Yet another reason why I love the Ubuntu (Linux) community - others helping others.
                      good.
                      glad it was useful.
                      2 things.
                      - no way i'd return the walkman: it's too good!
                      - intrepid (8.10) ships with libmtp 0.3.0, which includes support for our dev
                      take care... 8)
                        Indeed! Very intuitive user interface and superior audio from the headset. I noticed the GNU general and less public licenses reprinted on the copyright sheet so I went looking at Sony's site to see which open source products they used for the unit. I found the following:
                        # busybox-1.1.0.tar.gz
                        # dosfstools-2.11.local.tgz
                        # e2fsprogs-1.35-2.0.0.0501450.src.rpm
                        # gcc-3.4.3-25.0.43.0501450.src.rpm
                        # glibc-2.3.3-40.0.35.0501450.src.rpm
                        # linux-kernel-2.6.10.local.tgz
                        # lrzsz-0.12.20.tar.gz
                        # mtd-utils-2.6.9_1.1-6.0.0.0501450.src.rpm
                        # ncurses-5.4-1.0.0.0501450.src.rpm
                        # procps-3.2.6.tar.gz
                        # sysvinit-2.85.tar.gz
                        # u-boot-1.1.1.local.tgz
                        Interesting for Sony. I'm very pleased with the purchase. The only wish list items I would want are dynamic playlists and Ogg support but maybe those will be forthcoming via a firmware update.
