Hello everybody!
I'm currently a Mandriva user and wanted to try Kubuntu, it seems like a nice and interesting distro.
I wanted to switch but I'm currently experiencing a problem with my USB external hard drive which stops me from doing so. This drive is using NTFS because I use it to go and help friends using Windows, I also use it when converting friends from Windows to Linux and as my personal drive for backups.
When I'm on Kubuntu, the drive mounts with no problem but some folders and files are missing, simply not appearing.
This is the only distro which gives me this problem; no problem under Ubuntu, Mandriva, MEPIS, Sidux...
Do you know what could be causing that? Do you know what would be the solution?
Thanks,
NiQCo
Thanks,
NiQCo
