I have been trying to install Kubuntu 7.1. Install starts normally but when it gets to the "Scanning Mirror" stage it takes a long, long time and then gives an error message to the effect that security updates on security.ubuntu.com cannot be accessed and you should investigate this later. It also says that commented out entries for security.ubuntu.com have been added to /etc/apt/sources.list.
At the end of install, all runs perfectly except that I cannot install any other packages such as Firefox, all are greyed out in the package list.
I checked out sources.list and it basically is a list of the appropriate directories on my local mirror ftp site, gb.archive.ubuntu.com/ubuntu/ as well as security.ubuntu.com. All entries are commented out and uncommenting does not have any effect, it will not let me install any other software.
Anyone with knowledge of how to correct this situation ?
Thanks
Thanks
