Wireless doesn't work after restart, microphone does nothing.
    Hello,
    I'm running Kubuntu 7.10 on an Acer Aspire 7520G.
    After some reading on the ubuntu forum i got my wireless to work, however, after each restart it won't search for an wireless network anymore. I need to type this to get it working.
    wlanconfig ath0 destroy
    wlanconfig ath0 create wlandev wifi0 wlanmode sta
    ifconfig ath1 up
    for some reason I can stop ath0 and destroy it, but i can't make a new one, so it automatically takes ath1, which works until I reboot.
    anyone knows of this problem?
    as for my microphone, nothing works, I need it working with skype, but both my internal microphone and headset won't work.
    NOTE: sound output on the headphone does work.
    EDIT: After posting i saw that there's a separate category for wifi, I didn't know that, sorry.
    Re: Wireless doesn't work after restart, microphone does nothing.
    If you don't find a way to fix the problem, you might try to put those commands into an autostart script...then when you log in, those commands would be run automatically. It might not work, but probably worth a try...if you need help, let me know, and I can help you out with it...
    mm0
    Dell Inspiron 1720 Laptop<br />Intel T9300 Core2Duo Processor @ 2.5Ghz<br />4 GB Ram | 1920 X 1200 Resolution<br />2 X 160 GB SATA HD Internal<br />Nvidia GeForce 8600M Graphics Adapter<br />Using Kubuntu 9.10
      I fixed my network, there was a line in /etc/network/interfaces
      about ath0 I removed it and now it works again, anyone some ideas for my microphone?
