Monitor & Display System Settings crashed
    The Monitor and System settings crashed when I configuring my monitor(Benq FP92W) to to display in widescreen the traceback follows.
    Display Sys(no debugging symbols found)
    Using host libthread_db library "/lib/tls/i686/cmov/libthread_db.so.1".
    [Thread debugging using libthread_db enabled]
    [New Thread -1233299232 (LWP 5752)]
    [KCrash handler]
    #6 0xb7f43410 in __kernel_vsyscall ()
    #7 0xb7ceedf0 in raise () from /lib/tls/i686/cmov/libc.so.6
    #8 0xb7cf0641 in abort () from /lib/tls/i686/cmov/libc.so.6
    #9 0xb7ce843b in __assert_fail () from /lib/tls/i686/cmov/libc.so.6
    #10 0xb68196f4 in xcb_xlib_lock () from /usr/lib/libxcb-xlib.so.0
    #11 0xb69eac8c in ?? () from /usr/lib/libX11.so.6
    #12 0x0805a9d8 in ?? ()
    #13 0x0000011b in ?? ()
    #14 0xb6ab7000 in ?? ()
    #15 0x00804d1c in ?? ()
    #16 0xb6a8fa4c in ?? () from /usr/lib/libX11.so.6
    #17 0x0805a468 in ?? ()
    #18 0xbf9b154c in ?? ()
    #19 0xb69c7225 in XFreeCursor () from /usr/lib/libX11.so.6
    Backtrace stopped: frame did not save the PC
