Severe performance issues / memory leaks on fresh 25.10 installation
    [Post-Install] Severe performance issues / memory leaks on fresh 25.10 installation
    After several years with KDE Neon I am trying to migrate some of my systems back to Kubuntu for longer support and greater stability ... I hoped ...
    I formated the disk (as predefined by the installer) and made a fresh install. I made some global configuration choices, moved files back and also started to gradually migrate old configuration for applications to the new user as I noticed that plasma is laggy (mouse pointer movement not smooth).
    I noticed that under Wayland plasma and kwin_wayland consume large and increasing amounts of memory (can become Gigabytes) before I have to restart them or do a hard reset.
    Without success, I did the following trying to fix the issue:
    * Roll back some custom settings that I made.
    * Install newer plasma and kde from the ubuntu-backports ppa.
    * Shutting down the usual suspects that have caused headaches in the past (e.g., Baloo file search, akonadi and apparmor).
    * Install Xorg instead of Wayland.
    * Reset the custom user plasma configuration.
    * Test with an entirely new user account without files.
    Now I am still stuck with the essentially same issue, can work under X, but only briefly use Dolphin.
    While Wayland gets immediately laggy and soon unusable I can work under X with limitations:
    Under X dolphin and kglobalaccel5 (which handles global keyboard shortcuts) apparently leak memory.
    For latter it is sufficient to kill and restart it (after which it will work and not leak anymore).
    However dolphin eats Gigabytes of memory and can cause the whole system to lag.
    I ran heaptrack on Dolphin under X with the result:
    total runtime: 3047.02s.
    calls to allocation functions: 648550909 (212847/s)
    temporary memory allocations: 212269633 (69664/s)
    peak heap memory consumption: 581.62M
    peak RSS (including heaptrack overhead): 862.61M
    total memory leaked: 549.41M
    suppressed leaks: 503.80K
    The gui version unfortunately quits with a Segfault, so no screenshots.
    If I read the terminal log correctly​ the leaks are here:
    175574559 calls to allocation functions with 467.46M peak consumption from
    QArrayData::allocate2(QArrayData**, long long, QArrayData::AllocationOption)
      in /lib/x86_64-linux-gnu/libQt6Core.so.6
    7758708 calls with 0B peak consumption from:
        QString::fromLatin1(QByteArrayView)
        0x72bff5e07a89
        0x72bff5e02f4e
        0x72bff5e0847f
        QMimeType::inherits(QString const&) const
        0x72bff802000e
          in /lib/x86_64-linux-gnu/libKF6Service.so.6
        KBuildSycoca::recreate(bool)
        KSycocaPrivate::buildSycoca()
        KSycocaPrivate::checkDatabase(QFlags<>)
        KSycoca::ensureCacheValid()
        KService::serviceByDesktopName(QString const&)
        0x61c104702c62
          in /usr/bin/dolphin
        0x61c1047040a1
          in /usr/bin/dolphin
        0x72bff5be4a94​
    My system is reasonably recent with sufficient memory:
    ~> inxi -Fzxx
    System:
    Kernel: 6.17.0-6-generic arch: x86_64 bits: 64 compiler: gcc v: 15.2.0
    Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
    Distro: Kubuntu 25.10 (Questing Quokka) base: Ubuntu
    Machine:
    Type: Laptop System: TUXEDO product: TUXEDO InfinityBook S 15 Gen6 v: N/A
    serial: <superuser required> Chassis: type: 10 serial: <superuser required>
    Mobo: NB01 model: NS50MU serial: <superuser required> part-nu: IBS1506
    UEFI: INSYDE v: 1.07.03RTR date: 09/07/2020
    Battery:
    ID-1: BAT0 charge: 25.2 Wh (71.8%) condition: 35.1/73.9 Wh (47.5%)
    volts: 8.35 min: 7.7 model: Notebook BAT serial: <filter> charging:
    status: charging cycles: N/A
    CPU:
    Info: quad core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 12 MiB
    Speed (MHz): avg: 400 min/max: 400/4700 cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 bogomips: 44851
    Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    Graphics:
    Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: CLEVO/KAPOK
    driver: i915 v: kernel arch: Xe ports: active: HDMI-A-1,eDP-1
    empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
    Device-2: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 bus-ID: 3-7:3 chip-ID: 04f2:b6f9
    Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: modesetting unloaded: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    Screen-1: 0 s-res: 4480x1440 s-dpi: 96
    Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: top-left
    model: LG (GoldStar) HDR 4K res: 2560x1440 hz: 60 dpi: 108
    diag: 690mm (27.2")
    Monitor-2: eDP-1 pos: primary,bottom-r model: LG Display 0x0612
    res: 1920x1080 hz: 60 dpi: 142 diag: 395mm (15.5")
    API: EGL v: 1.5 platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
    drv: iris surfaceless: drv: iris x11: drv: iris inactive: wayland
    API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-1ubuntu1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
    GT2) device-ID: 8086:9a49
    API: Vulkan v: 1.4.321 surfaces: xcb,xlib device: 0 type: integrated-gpu
    driver: mesa intel device-ID: 8086:9a49 device: 1 type: cpu
    driver: mesa llvmpipe device-ID: 10005:0000
    Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
    de: kscreen-console,kscreen-doctor gpu: gputop, intel_gpu_top, lsgpu
    wl: wayland-info x11: xdriinfo, xdpyinfo, xprop, xrandr
    Audio:
    Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: CLEVO/KAPOK
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a0c8
    API: ALSA v: k6.17.0-6-generic status: kernel-api
    Server-1: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active
    Network:
    Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 34:00.0 chip-ID: 10ec:8168
    IF: enp52s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie:
    speed: 5 GT/s lanes: 1 bus-ID: 35:00.0 chip-ID: 8086:2723
    IF: wlp53s0 state: down mac: <filter>
    Bluetooth:
    Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 bus-ID: 3-10:4 chip-ID: 8087:0029
    Report: hciconfig ID: hci0 rfk-id: 0 state: down bt-service: disabled
    rfk-block: hardware: no software: yes address: <filter>
    Drives:
    Local Storage: total: 931.51 GiB used: 695.26 GiB (74.6%)
    ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO M.2 1TB size: 931.51 GiB
    speed: 6.0 Gb/s serial: <filter>
    Partition:
    ID-1: / size: 911.58 GiB used: 695.03 GiB (76.2%) fs: ext4 dev: /dev/dm-0
    mapped: luks-96592687-b3d2-4220-b379-ecf7b063f132
    ID-2: /boot size: 3.86 GiB used: 229.3 MiB (5.8%) fs: ext4 dev: /dev/sda2
    ID-3: /boot/efi size: 299.4 MiB used: 8 MiB (2.7%) fs: vfat dev: /dev/sda1
    Swap:
    ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
    Sensors:
    System Temperatures: cpu: 44.0 C mobo: N/A
    Fan Speeds (rpm): N/A
    Info:
    Memory: total: 32 GiB available: 31.14 GiB used: 6.87 GiB (22.1%)
    Processes: 306 Power: uptime: 37m wakeups: 0 Init: systemd v: 257
    default: graphical
    Packages: pm: dpkg pkgs: 2944 Compilers: gcc: 15.2.0 Shell: Bash v: 5.2.37
    running-in: yakuake inxi: 3.3.39
    Any help appreciated!
    For more information and future reference, the bug report is here: https://bugs.kde.org/show_bug.cgi?id=512869 .
      I'm not the one to answer any of your questions really, but you've definitely got something wrong with your system. I'm on 25.10 and use a i5 10th gen processor (nothing special) and my mouse works perfect. Dolphin on my system only uses 180mib of ram. What you're describing just sounds insane to me. I would just try reinstalling the system, but again, I'm no expert on linux at all. Good luck to you
