Kubuntu recently decided to quit mounting my second hard drive. I'm not sure what caused this, but I think it came with an update. When I run kcmshell4 device_automounter_kcm, the box for "Automount on Login" is checked for the drive. When I run sudo fdisk -l, the drive is listed, but underneath it in red it says
	I found that if I manually create a mount point, I can get it to mount with the "mount" command, and everything seems to work fine. I wonder if I found a bug in KDE, and, if so, which part.
	Partition 2 does not start on physical sector boundary.
