There is a thread marked [SOLVED] with the same problem listed below (can't post the link to it as this is my first post). Since the offered solution didn't work for me, I am starting a new one, hopefully it's not against the rules (I couldn't find anything on that).
It is a desktop machine running Kubuntu 14.04 since April, and problems appeared (I assume) after an apt update/upgrade back in very late July or early August. I shut down, went on a longish vacation and when I got back this was waiting for me. Before that update (or my vacation) everything was working fine. Don't go on vacation!
So, upon logging in, I get this notification
Anyway, here is what else is happening.
1. I have no network connection - all adapters appear to be disabled and I don't seem to be able to do much about it. My PC is connected using an on-board wi-fi, which is definitely working fine because I am running a dual boot with Win8 and I have no problems there.
2. Upon clicking the Leave button, the only option I get is Logout - no Restart, no Suspend, no Shutdown - and once I do logout, on the login screen all these options are greyed out. If I try to shut down from the terminal the PC hangs (I have waited for about an hour before I performed the hard reset). In System Settings - Session Management, "Offer shutdown options" is checked, as it was before the problem appeared.
When I go to System Settings - Power Management, everything is greyed out and there is the message
Regardless of what I do with the Power Management in Service Manager - set it as a startup service (the way it was when I first noticed the problem, and it was "running" then) or not - it's always the same. If I stop the service and then restart it, I get the first message.
Any help?
Thanks.
KDE Power Management System could not be initialized. The backend reported the following error: No valid Power Management backend plugins are available. A new installation might solve this problem. Please check your system configuration
Power Management configuration module could not be loaded. The Power Management Service appears not to be running. This can be solved by starting it inside "Startup and Shutdown"
Any help?
Thanks.
