HDMI Sound Output
    HDMI Sound Output
    Hi there, I'm hoping someone can help me set up HDMI sound, so that Kubuntu 14.04 works with my television?
    This used to work no problem, out of the box, with Ubuntu 14.04, but since the switch over to Kubuntu 14.04, I'm not sure how to get it to work.
    Your help will definitely be appreciated.
    https://www.kubuntuforums.net/showth...highlight=HDMI
    https://www.kubuntuforums.net/showth...ght=hdmi+sound
      right click the speaker icon in the system tray>click Audio set up>click the Audio hardware set up tab ,,,,,,,,,,,,, play with the settings wile audio should be playing through the HDMI until you hear it .
        Thanks. I'm a Kubuntu n00b. Didn't think it was as simple as right-clicking on the volume button and playing around.
          so we can assume you got it working ??
            Yes, thanks. I'll mark the issue solved now. There's definitely a learning curve to KDE... not a bad thing in any way; thank goodness this forum is here.
