help.... since a week or so ago when i try my aptitude safe-upgrade (or full-upgrade) i got this output:
root@avatar:~# sudo aptitude safe-upgrade
Resolving dependencies...
cvs{a} cvsservice{a}
bsdutils cervisia dbus-x11 gir1.2-gtk-3.0 libcap-ng0
libdatetime-timezone-perl libgtk-3-0 libgtk-3-bin
libgtk-3-common libmm-glib0 libmount1 libogg-dev libogg0
libogg0:i386 libsigc++-2.0-0c2a libtalloc2 libtdb1 libvlc5
libvlccore7 libwhoopsie0 modemmanager project-neon-calligra
project-neon-calligra-dbg project-neon-juk
project-neon-juk-dbg project-neon-kde-dev-scripts
project-neon-kdepim-runtime project-neon-kdepim-runtime-dbg
project-neon-kdepimlibs project-neon-kdepimlibs-dbg
project-neon-kopete project-neon-kopete-dbg
project-neon-libqapt project-neon-libqapt-dbg
project-neon-muon project-neon-muon-dbg project-neon5-kauth
project-neon5-kcompletion project-neon5-kconfigwidgets
project-neon5-kdesignerplugin project-neon5-kdesu
project-neon5-kdoctools project-neon5-kemoticons
project-neon5-kiconthemes project-neon5-kjobwidgets
project-neon5-kjsembed project-neon5-knotifications
project-neon5-knotifications-dbg project-neon5-kpty
project-neon5-kservice project-neon5-ktextwidgets
project-neon5-kunitconversion project-neon5-kwallet
project-neon5-kxmlgui project-neon5-kxmlgui-dbg
pyqt4-dev-tools python-qt4 python-qt4-dbg python-qt4-dbus
python-qt4-gl python-qt4-sql python-talloc python-tdb
python3-dbus.mainloop.qt python3-pyqt4 resolvconf tdb-tools
util-linux uuid-runtime vlc vlc-data vlc-dbg vlc-nox
vlc-plugin-notify vlc-plugin-pulse whoopsie
The following partially installed packages will be configured:
acpid apache2 apport apport-kde at avahi-daemon bluez
bluez-alsa bluez-cups chromium-browser chromium-browser-l10n
chromium-codecs-ffmpeg-extra console-setup cron cryptsetup
cups cups-core-drivers cups-daemon dbus dragonplayer gimp
ifupdown initscripts kdelibs-bin kdelibs5-plugins kdoctools
keyboard-configuration libgegl-0.3-0 libgegl-dev libgimp2.0
libkdcraw23 libkde3support4 libkdewebkit5 libkemoticons4
libkfile4 libkhtml5 libkimproxy4 libkio5 libkipi11
libkmediaplayer4 libknewstuff2-4 libknewstuff3-4
libknotifyconfig4 libkparts4 libkprintutils4 libkrossui4
libktexteditor4 libkunitconversion4 libkutils4 libpam-systemd
libplasma3 libsolid4 lsb-core nvidia-common openssh-server ppp
prerex procps project-neon-ark project-neon-ark-dbg
project-neon-cantor project-neon-cantor-dbg project-neon-kate
project-neon-kate-dbg project-neon-kcachegrind
project-neon-kcachegrind-dbg project-neon-kde-baseapps
project-neon-kde-baseapps-dbg project-neon-kde-workspace
project-neon-kde-workspace-dbg project-neon-kdelibs
project-neon-kdelibs-dbg project-neon-kdeplasma-addons
project-neon-kdeplasma-addons-dbg project-neon-marble
project-neon-marble-dbg project-neon-plasma-mediacenter
project-neon-plasma-mediacenter-dbg project-neon-umbrello
project-neon-umbrello-dbg project-neon5-khotkeys
project-neon5-plasma-desktop project-neon5-plasma-workspace
project-neon5-plasma-workspace-dbg project-neon5-powerdevil
project-neon5-session pulseaudio pulseaudio-module-bluetooth
pulseaudio-module-x11 rsyslog ssh systemd texlive-latex-extra
texlive-pstricks ubuntu-drivers-common udev udisks2 vprerex
76 packages upgraded, 2 newly installed, 0 to remove and 2 not upgraded.
Need to get 0 B/405 MB of archives. After unpacking 4098 kB will be used.
Do you want to continue? [Y/n/?] y
Razširjanje predlog iz paketov: 100%
Prednastavljanje paketov ...
(Reading database ... 743349 files and directories currently installed.)
Preparing to unpack .../util-linux_2.20.1-5.1ubuntu21_amd64.deb ...
insserv: There is a loop at service udev if started
insserv: loop involving service udev at depth 1
insserv: There is a loop at service cryptdisks-early if started
insserv: loop involving service procps at depth 5
insserv: loop involving service cryptdisks at depth 5
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing archive /var/cache/apt/archives/util-linux_2.20.1-5.1ubuntu21_amd64.deb (--unpack):
subprocess new pre-installation script returned error exit status 1
A package failed to install. Trying to recover:
Setting up dbus (1.6.18-0ubuntu7) ...
dpkg: error processing package dbus (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up texlive-pstricks (2014.20140528-2) ...
Setting up at (3.1.14-1ubuntu2) ...
dpkg: error processing package at (--configure):
Setting up acpid (1:2.0.21-1ubuntu3) ...
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match acpid Default-Stop values (none)
dpkg: error processing package acpid (--configure):
Setting up keyboard-configuration (1.70ubuntu9) ...
No protocol specified
Cannot open display ":0"
Your console font configuration will be updated the next time your system
boots. If you want to update it now, run 'setupcon' from a virtual console.
dpkg: error processing package keyboard-configuration (--configure):
Setting up initscripts (2.88dsf-41ubuntu16) ...
insserv: There is a loop between service mountdevsubfs and udev if started
insserv: loop involving service udev at depth 3
insserv: loop involving service mountdevsubfs at depth 2
insserv: loop involving service checkroot at depth 6
dpkg: error processing package initscripts (--configure):
Setting up texlive-latex-extra (2014.20140528-2) ...
dpkg: dependency problems prevent configuration of dbus-x11:
dbus-x11 depends on dbus; however:
Package dbus is not configured yet.
dpkg: error processing package dbus-x11 (--configure):
dependency problems - leaving unconfigured
Setting up prerex (6.4.0-3) ...
dpkg: dependency problems prevent configuration of udisks2:
udisks2 depends on dbus; however:
dpkg: error processing package udisks2 (--configure):
Setting up cryptsetup (2:1.6.1-1ubuntu3) ...
update-initramfs: deferring update (trigger activated)
egrep: /etc/crypttab: Datoteka ali imenik s tem imenom ne obstaja
insserv: Service checkroot has to be enabled to start service cryptdisks-early
insserv: exiting now!
dpkg: error processing package cryptsetup (--configure):
Setting up cron (3.0pl1-124ubuntu4) ...
update-rc.d: warning: stop runlevel arguments (1) do not match cron Default-Stop values (none)
dpkg: error processing package cron (--configure):
dpkg: dependency problems prevent configuration of project-neon-kdelibs:
project-neon-kdelibs depends on dbus-x11; however:
Package dbus-x11 is not configured yet.
dpkg: error processing package project-neon-kdelibs (--configure):
dpkg: dependency problems prevent configuration of avahi-daemon:
avahi-daemon depends on dbus (>= 1.2.16-0ubuntu3); however:
dpkg: error processing package avahi-daemon (--configure):
dpkg: dependency problems prevent configuration of rsyslog:
rsyslog depends on initscripts (>= 2.88dsf-13.3); however:
Package initscripts is not configured yet.
dpkg: error processing package rsyslog (--configure):
Setting up apport (2.14.3-0ubuntu1) ...
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match apport Default-Stop values (none)
dpkg: error processing package apport (--configure):
dpkg: dependency problems prevent configuration of project-neon-kdeplasma-addons:
project-neon-kdeplasma-addons depends on project-neon-kdelibs; however:
Package project-neon-kdelibs is not configured yet.
dpkg: error processing package project-neon-kdeplasma-addons (--configure):
dpkg: dependency problems prevent configuration of kdelibs5-plugins:
kdelibs5-plugins depends on dbus-x11; however:
dpkg: error processing package kdelibs5-plugins (--configure):
dpkg: dependency problems prevent configuration of procps:
procps depends on initscripts; however:
dpkg: error processing package procps (--configure):
dpkg: dependency problems prevent configuration of project-neon-kcachegrind:
project-neon-kcachegrind depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-kcachegrind (--configure):
dpkg: dependency problems prevent configuration of project-neon-kdeplasma-addons-dbg:
project-neon-kdeplasma-addons-dbg depends on project-neon-kdeplasma-addons (= 2+git20140601+r5698-15~ubuntu13.10.1); however:
Package project-neon-kdeplasma-addons is not configured yet.
dpkg: error processing package project-neon-kdeplasma-addons-dbg (--configure):
dpkg: dependency problems prevent configuration of project-neon-calligra:
project-neon-calligra depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-calligra (--configure):
dpkg: dependency problems prevent configuration of project-neon-ark:
project-neon-ark depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-ark (--configure):
dpkg: dependency problems prevent configuration of project-neon-kdepim-runtime:
project-neon-kdepim-runtime depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-kdepim-runtime (--configure):
dpkg: dependency problems prevent configuration of lsb-core:
lsb-core depends on at; however:
Package at is not configured yet.
lsb-core depends on cron | cron-daemon; however:
Package cron is not configured yet.
Package cron-daemon is not installed.
Package cron which provides cron-daemon is not configured yet.
lsb-core depends on procps; however:
Package procps is not configured yet.
dpkg: error processing package lsb-core (--configure):
dpkg: dependency problems prevent configuration of bluez:
bluez depends on dbus; however:
dpkg: error processing package bluez (--configure):
dpkg: dependency problems prevent configuration of project-neon-calligra-dbg:
project-neon-calligra-dbg depends on project-neon-calligra (= 2+git20140601+r75484-33~ubuntu13.10.1); however:
Package project-neon-calligra is not configured yet.
dpkg: error processing package project-neon-calligra-dbg (--configure):
dpkg: dependency problems prevent configuration of project-neon-muon:
project-neon-muon depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-muon (--configure):
dpkg: dependency problems prevent configuration of ifupdown:
ifupdown depends on initscripts (>= 2.88dsf-25); however:
dpkg: error processing package ifupdown (--configure):
dpkg: dependency problems prevent configuration of project-neon-cantor:
project-neon-cantor depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-cantor (--configure):
dpkg: dependency problems prevent configuration of project-neon-kdepimlibs:
project-neon-kdepimlibs depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-kdepimlibs (--configure):
dpkg: dependency problems prevent configuration of project-neon-kcachegrind-dbg:
project-neon-kcachegrind-dbg depends on project-neon-kcachegrind (= 2+git20140529+r746~fbedde3-25~ubuntu13.10.1); however:
Package project-neon-kcachegrind is not configured yet.
dpkg: error processing package project-neon-kcachegrind-dbg (--configure):
dpkg: dependency problems prevent configuration of console-setup:
console-setup depends on keyboard-configuration; however:
Package keyboard-configuration is not configured yet.
dpkg: error processing package console-setup (--configure):
dpkg: dependency problems prevent configuration of ppp:
ppp depends on procps; however:
dpkg: error processing package ppp (--configure):
dpkg: dependency problems prevent configuration of project-neon-juk:
project-neon-juk depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-juk (--configure):
dpkg: dependency problems prevent configuration of bluez-alsa:amd64:
bluez-alsa:amd64 depends on bluez; however:
Package bluez is not configured yet.
dpkg: error processing package bluez-alsa:amd64 (--configure):
dpkg: dependency problems prevent configuration of systemd:
systemd depends on initscripts (>= 2.88dsf-17); however:
dpkg: error processing package systemd (--configure):
dpkg: dependency problems prevent configuration of project-neon-umbrello:
project-neon-umbrello depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-umbrello (--configure):
dpkg: dependency problems prevent configuration of project-neon-cantor-dbg:
project-neon-cantor-dbg depends on project-neon-cantor (= 2+git20140531+r850-10~ubuntu13.10.1); however:
Package project-neon-cantor is not configured yet.
dpkg: error processing package project-neon-cantor-dbg (--configure):
dpkg: dependency problems prevent configuration of project-neon-kde-workspace:
project-neon-kde-workspace depends on project-neon-kdelibs; however:
project-neon-kde-workspace depends on project-neon-kdepimlibs; however:
Package project-neon-kdepimlibs is not configured yet.
dpkg: error processing package project-neon-kde-workspace (--configure):
dpkg: dependency problems prevent configuration of project-neon-muon-dbg:
project-neon-muon-dbg depends on project-neon-muon (= 2+git20140531+r2113-24~ubuntu13.10.1); however:
Package project-neon-muon is not configured yet.
dpkg: error processing package project-neon-muon-dbg (--configure):
dpkg: dependency problems prevent configuration of apport-kde:
apport-kde depends on apport (>= 0.41); however:
Package apport is not configured yet.
apport-kde depends on procps; however:
dpkg: error processing package apport-kde (--configure):
dpkg: dependency problems prevent configuration of project-neon-kate:
project-neon-kate depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-kate (--configure):
dpkg: dependency problems prevent configuration of project-neon-ark-dbg:
project-neon-ark-dbg depends on project-neon-ark (= 2+git20140602+r2517-6~ubuntu13.10.1); however:
Package project-neon-ark is not configured yet.
dpkg: error processing package project-neon-ark-dbg (--configure):
dpkg: dependency problems prevent configuration of project-neon-juk-dbg:
project-neon-juk-dbg depends on project-neon-juk (= 2+git20140601+r2460-22~ubuntu13.10.1); however:
Package project-neon-juk is not configured yet.
dpkg: error processing package project-neon-juk-dbg (--configure):
dpkg: dependency problems prevent configuration of project-neon-plasma-mediacenter:
project-neon-plasma-mediacenter depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-plasma-mediacenter (--configure):
dpkg: dependency problems prevent configuration of project-neon-kdepim-runtime-dbg:
project-neon-kdepim-runtime-dbg depends on project-neon-kdepim-runtime (= 2+git20140529+r8792-24~ubuntu13.10.1); however:
Package project-neon-kdepim-runtime is not configured yet.
dpkg: error processing package project-neon-kdepim-runtime-dbg (--configure):
dpkg: dependency problems prevent configuration of apache2:
apache2 depends on procps; however:
dpkg: error processing package apache2 (--configure):
dpkg: dependency problems prevent configuration of project-neon-marble:
project-neon-marble depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-marble (--configure):
dpkg: dependency problems prevent configuration of openssh-server:
openssh-server depends on procps; however:
dpkg: error processing package openssh-server (--configure):
dpkg: dependency problems prevent configuration of cups-daemon:
cups-daemon depends on procps; however:
dpkg: error processing package cups-daemon (--configure):
dpkg: dependency problems prevent configuration of project-neon-kde-baseapps:
project-neon-kde-baseapps depends on project-neon-kdelibs; however:
dpkg: error processing package project-neon-kde-baseapps (--configure):
dpkg: dependency problems prevent configuration of project-neon-kdelibs-dbg:
project-neon-kdelibs-dbg depends on project-neon-kdelibs (= 2+git20140529+r92483~9cd3b72-68~ubuntu13.10.1); however:
dpkg: error processing package project-neon-kdelibs-dbg (--configure):
dpkg: dependency problems prevent configuration of udev:
udev depends on procps; however:
dpkg: error processing package udev (--configure):
dpkg: too many errors, stopping
Processing triggers for tex-common (5.02) ...
Running mktexlsr. This may take some time... done.
Running updmap-sys. This may take some time... done.
Running mktexlsr /var/lib/texmf ... done.
Processing triggers for menu (2.1.46ubuntu1) ...
Processing triggers for initramfs-tools (0.103ubuntu6) ...
update-initramfs: Generating /boot/initrd.img-3.15.0-4-generic
W: Possible missing firmware /lib/firmware/radeon/HAINAN_mc2.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/OLAND_mc2.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/VERDE_mc2.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/PITCAIRN_mc2.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/TAHITI_mc2.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/MULLINS_sdma.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/MULLINS_rlc.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/MULLINS_mec.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/MULLINS_ce.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/MULLINS_me.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/MULLINS_pfp.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/HAWAII_mc2.bin for module radeon
W: Possible missing firmware /lib/firmware/radeon/BONAIRE_mc2.bin for module radeon
dbus
at
acpid
initscripts
dbus-x11
udisks2
cryptsetup
cron
avahi-daemon
rsyslog
apport
kdelibs5-plugins
procps
project-neon-ark
lsb-core
bluez
project-neon-muon
ifupdown
project-neon-cantor
console-setup
ppp
project-neon-juk
bluez-alsa:amd64
systemd
apport-kde
project-neon-kate
apache2
project-neon-marble
openssh-server
cups-daemon
udev
Processing was halted because there were too many errors.
root@avatar:~#
so far the system still reboots fine, but the number of programs having problems is increasing... is there a way to solve this issue, or you suggest a complete re-install...?
sincerely thank you for your help
Simon :/
dbus
at
acpid
initscripts
dbus-x11
udisks2
cryptsetup
cron
avahi-daemon
rsyslog
apport
kdelibs5-plugins
procps
project-neon-ark
lsb-core
bluez
project-neon-muon
ifupdown
project-neon-cantor
console-setup
ppp
project-neon-juk
bluez-alsa:amd64
systemd
apport-kde
project-neon-kate
apache2
project-neon-marble
openssh-server
cups-daemon
udev
root@avatar:~#
Simon :/
