Hello,
Here is my situation. I am currently running Kubuntu 13.10, dual boot with Window 7 on my laptop. I just get a new laptop with a much better spec and the same amount of storage. I want to move my current Kubuntu and Window 7 system to this new laptop. Here is what I did:
- I used deja-dupe backup to back up my current Kubuntu 13.10
- Then I transferred my backup to external drive
- I used Kubuntu 13.10 USB Live Environment on the new laptop to install deja-dupe and recover the backup to the new laptop.
- The recovery process was successful.
- I then used GRUB-repair to repair GRUB boot.
- After repair, I was able to boot into Kubuntu 13.10 on my new laptop but I got a black screen after Kubuntu loading screen.
So, basically what I did is the same as using dd or cp to copy entire partition from one hard drive to another. I just used deja-dupe because you don't have to take the hard drive out of the laptop. I fully expected errors to happen (due to different drivers between laptop); but the problem is I am not sure how to diagnose these errors. I was able to boot into recovery mode on the new laptop and load up shell prompt. I suspect the video driver did not load up correctly. I need some help or tip on what command I should used to diagnose and potentially repair my Kubuntu recovery.
Worst case scenario, I can just wipe the recovery and install a new Kubuntu 13.10 on top but I just want to try and see what I can do to solve this problem first. Thank you for your help.
