If you're like me, you use Firefox and Thunderbird *a lot*. There is a bug in the gtk2-engines-oxygen package which causes these two Mozilla-distributed applications to freeze unexpectedly or run unacceptably slowly in Kubuntu Raring. Some people have tried switching to other GTK themes to alleviate the problem. I tried using Raleigh and it helped with the freezing, but not the slowness. (Also, Raleigh is ugly compared to Oxygen).
Thankfully, Petr Sedlacek (petr-sedlacek) has made available a .deb with an updated gtk2-engines-oxygen package for 64-bit systems that makes this problem go away. It's worked for several people subscribed to the bug on Launchpad and it definitely worked for me.
Get it here:
https://dl.dropboxusercontent.com/u/...ched_amd64.deb
Just download, install the package, and restart your system. You should see a noticeable improvement with both Firefox and Thunderbird.
Hope this helps someone. This issue was extremely frustrating to me and it's nice to be able to move on with a stable system.
Get it here:
