Problems cleaning up my system
    Ive been going through trying to clean up unnecessary junk from my system the last few days. Ive deleted several unused packages, run bleachbit with and without root, deleted residual config files, run deborphan etc. and after all this, my system is 3 GB heavier than it was. Whats going on here??
    What the disk information utilities are telling ? Various applications: http://www.kubuntuforums.net/showthr...ce-Regenerated
    Have you tried ?
    - How to Ask a Question on the Internet and Get It Answered
    - How To Ask Questions The Smart Way
      Perhaps something obvious, but have you emptied the trash folder?
      Frank.
        For such cases, where you don't know where all the space went, there's a very useful tool: Baobab
        Simply install it from the main repositories.
        You can either look at an entire partition, or just a single folder (e.g. your home folder), and it gives you a detailled pie chart of which folders and files take up how much space.
        Kubuntu Raring Ringtail x64 w/ Kde 4.10.5
        Multimedia packages for Kubuntu x64 (x264 10bit, mplayer2, Aegisub etc.)
        http://erokawaii.org/?page_id=5181
        My stuff on kde-look.org
        http://kde-look.org/usermanager/sear...ction=contents
          Interesting. Even though it's a Gnome utility, it is extremely light on dependencies:
          baobab libgtop2-7 libgtop2-common
          0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
            filelight is the similar KDE utility.
              Almost all of this is in /usr. Out of all the disk space used, nearly 87% is in /usr and in /usr /lib /share and /local contain the majority of the data. Heres the readout of xdiskusage for /usr:
                It seems that you have some debug packages installed (/usr/lib/debug...). They are taking almost 1 G (953,3M).
                Have you tried ?
                  Sometimes when there is a buggy app it can produce very big log files. They are in /var/log. I had log files bigger that 2 GB. From time to time I also clean .thumbnails folder on /home.
                    As many of you know, I'm behind in checking, editing, updating my how-to's at KFN, but, who knows, maybe there's a tip or two in this one that might trigger some ideas:
                    Privacy Cleanup 101
                    http://www.kubuntuforums.net/showthr...cy-Cleanup-101
                      How do I uninstall unneeded debug packages?
                        Same way you installed them - by your favorite package manager.
                        Have you tried ?
