Hi, yes I've developed some new problems. Due to an enormous error on my part, I had to reinstall 12.04 again and ended up with some difficulties. One problem that predates the reinstallation is this, I recently added a 3d graphics card. The card is an older Aopen Mx400 with 64mb. Since putting it in when I boot up right after my grub menu selection my screen appears to go into sleep mode (amber light on my monitor lights up and screen goes blank for about 2 minutes). Not really sure if there is a work around, but I assume the system reads it because it's listed in my system settings menu.
After this reinstallation, I can't seem to change my login screen in the settings menu. When I select new themes they don't show up on the selection menu. When I looked it up in the KDE instructions it said you have to do this as a superuser, but I had assumed when it asked you for your password at the start of login screen settings, that is what it was doing.
One final issue after this reinstallation, I get no splash screen. After logging in, my user name/ password icon dissapears leaving the gray rainbow and slowly fades to the desktop after a bit. None of the changing icons as it builds as usual in the splash screen. Any ideas?
Thanx,
capt-zero
Thanx,
capt-zero
