Dear all,
I have been experiencing some trouble with booting my pc recently and need some help fixing it. To cut a long story short, the fix I need is only temporary - because I hope to upgrade to 12.04 as soon as possible, and I only really need to boot back into the GUI so that I can make a full back-up before making the jump with a clean install. As such, booting into the GUI once, without even fixing the system is fine.
There are two reasons why I think I need to get back into a gui - firstly, I wanted to make use of the 'export list of installed programs' option in the software manager (to make for easier reinstallation) - and secondly, because the /home drive is encrypted, and I need to be able to access the drive as decrypted before I back-up all data to an external USB drive (vfat).
After much trouble, I do now have access to a command-line interface and a booting kernel - but KDE will not start because of problems with the NVIDIA module. I can also access the filesystem from a chroot environment but that doesn't let me see the contents of /home.
From the command line inside the booting kernel, I have tried updating Nvidia - but it seems to fail, and in any case, even after attempting the update, the system will not currently boot to a GUI.
I have used a boot-repair cd, which seems to be an excellent utility - and in fact, that is what replaced grub2 files and the kernel to get me this far. However, I still need to get inside the system enough to be able to do a full back-up.
I had thought that I could do it all from the command line - but was having trouble mounting the external hard drive - and copying across all the data. Any pointers on that would be most appreciated...
So I have some questions.
1. What's the best way to fix NVIDIA from the command line and get the system booting back to KDE?
2. Assuming that this can't be done - or I come across more problems whilst attempting it - can someone point me in the right direction and guide me through how to mount my external hard drive and fully back-up all my KDE settings and encrypted data from my /home drive (in decrypted format)?
3. Alternatively - can anyone confirm what happens if I back up the encrypted /home drive and upgrade - what would be the procedure for accessing this encrypted data again from inside 12.04? Is that possible?
As a final aside - I already have the Kubuntu iso downloaded onto a partition on the hard drive in preparation for the clean install. So, for bonus points, rather than download it again on my wife's laptop, can anyone tell me how I can burn the iso file to a DVD from the command line? This will save me some download time/data - and would be pleasingly geeky at the same time - I've never used the cli for burning!
As you can see - I believe that there are several options to attack this problem - but I'd appreciate help in any of them to get me moving on to 12.04 safely, along with all my data!
Many thanks in advance for any help you can give me.
Regards,
Bag.
Regards,
Bag.
