installed 11.10 without a problem then..
    Muon said there was an update.. so I said run the updates.
    it stops at 57%.. I tried once.. reinstalled the OS and tried again..
    same thing..
    /var/log/dpkg.log has "installed kcalc 4:4.7.3-0ubuntu0.1"
    as its last entry
    /var/log/apt/term.log stopped at "prepairing to replace system-config-printer-kde.
    im not sure where else to look
    thanks !!
    mike
    Re: installed 11.10 without a problem then..
    How long did you wait before restarting/reinstalling? I often have updates that are choppy/slow, especially when my internet connection is bad. Nothing (yet) that took longer than 30 minutes to get going again though...
      ya it was over an hour..
      both times stuck at 57%..
      really odd.
        really odd.
        how mutch space did you give /
          the entire drive.. 120G
            try running the upgrade from a terminal
            at least you should be abel to see the progress and where it gets stuck or aborts and why.
            and just for the "be shur of it" post the output of
            df -h
            to see some space info...........the prob sounds a lot like a lack of space.
              good idea.. didnt think of that.. ill run it from a term.
              ill check the DF but the only way it could be out of space is if the installer didnt use the entire disk..
                really odd..
                just booted it up.. went to install firefox and got this.
                Another application seems to be using the package system at this time. You must close all other package managers before you will be able to install or remove any packages.
                but it doesnt look like update manager is running.
                running upgrade from term..
                tail end of output ....
                Hit http://us.archive.ubuntu.com oneiric-backports/main Translation-en
                Hit http://us.archive.ubuntu.com oneiric-backports/multiverse Translation-en
                Hit http://us.archive.ubuntu.com oneiric-backports/restricted Translation-en
                Hit http://us.archive.ubuntu.com oneiric-backports/universe Translation-en
                Fetched 873 kB in 2s (331 kB/s)
                E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
                root@gail-Satellite-A135:~#
                running dpkg --configure -a now..
                ohh ya.. DF looks good
                df -h
                Filesystem Size Used Avail Use% Mounted on
                /dev/sda1 110G 3.4G 101G 4% /
                udev 487M 4.0K 487M 1% /dev
                tmpfs 199M 788K 198M 1% /run
                none 5.0M 0 5.0M 0% /run/lock
                none 497M 1.4M 495M 1% /run/shm
                  Setting up kmail (4:4.7.3-0ubuntu0.1) ...
                  Processing triggers for initramfs-tools ...
                  update-initramfs: Generating /boot/initrd.img-3.0.0-14-generic
                  Processing triggers for libc-bin ...
                  ldconfig deferred processing now taking place
                  now ill try update again
                    that seems to have worked.
                    after the following....
                    Calculating upgrade... Done
                    app-install-data-partner freespacenotifier kde-l10n-engb kde-window-manager kde-workspace kde-workspace-bin kde-workspace-data kde-workspace-kgreet-plugins kdelibs-bin
                    kdelibs5-data kdelibs5-plugins kdm kdoctools kinfocenter klipper ksysguard ksysguardd libjasper1 libkcmutils4 libkde3support4 libkdecorations4 libkdecore5 libkdesu5 libkdeui5
                    libkdewebkit5 libkdnssd4 libkemoticons4 libkephal4abi1 libkfile4 libkhtml5 libkidletime4 libkio5 libkjsapi4 libkjsembed4 libkmediaplayer4 libknewstuff2-4 libknewstuff3-4
                    libknotifyconfig4 libkntlm4 libkparts4 libkprintutils4 libkpty4 libkrosscore4 libkscreensaver5 libksgrd4 libksignalplotter4 libktexteditor4 libkunitconversion4
                    libkwineffects1abi2 libkworkspace4 libnepomuk4 libnepomukquery4a libnepomukutils4 libplasma-geolocation-interface4 libplasma3 libplasmaclock4abi2 libplasmagenericshell4
                    libprocesscore4abi1 libprocessui4a libsolid4 libsolidcontrol4abi2 libsolidcontrolifaces4abi2 libtaskmanager4abi2 libthreadweaver4 libweather-ion6 plasma-dataengines-workspace
                    plasma-desktop plasma-netbook plasma-scriptengine-python plasma-widgets-workspace systemsettings
                    71 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 26.4 MB of archives.
                    After this operation, 90.1 kB of additional disk space will be used.
                    Do you want to continue [Y/n]? y
                    it finished and prompt for a reboot...
                    i rebooted.. it seems ok right now.
                    ill do the command line again and see if it says up2date.
                    however this is a laptop for my mother in law.. she knows nothing bout computers so I hope it will do the updates automatically from this point.
                      That's a problem with the *buntus, IMHO. Because of the "automatic update notification" feature, I chose Debian for my mother in-law's computer. She has not Clue #1 about the system, and I don't need a 9 p.m. Saturday night call about a broken computer ....
                      I would like to see a setting, accessible via super-user only, in systemsettings, that can turn off update notifications. Then the "system support staff" could use apt-get to run updates when visiting the supported system (or of course ssh could be implemented for remote updating). In other words, don't put the string that pulls the pin on the grenade into the hands of a novice.
                        well it wont do them automatically but it should work with the notifier now
                        aparently when muon got stuck it left you with
                        and now you have fixed this so things should be good for now ..........
                        you could put the terminal in the panel (a launcher) and leave her with instruction to run the command ...... when she sees the notifier..........if it was the last command run then hitting the up arrow ^ once will show it ......the up arrow will cycle through the terminal history
                          ya thats what I meant.. the panel will state there are updates..so she can click on it..
                          should I use or can I use another pkg manager?
                            ya thats true dibl
                              thanks to everyone for the help !!!!!
