Drag & drop audio conversion is broken (kioslave)
    Since upgrading to Oneiric, converting files from an audio CD via drag & drop is borked. The file type (MP3, Ogg, FLAC, etc) no longer appear when I use Dolpin to browse the CD. Incidentally, I can play the audio CD through Amarok. Also, I still have the Vorbis codecs installed, but I had to reinstall LAME via the Restricted Extras package.
    What am I missing?
    (Originally posted in Ocelot pre-release on 14 October 2011, 09:01:33, now closed.)
    In hindsight, everything can be funny<br />--Anonymous
    Re: Drag &amp; drop audio conversion is broken (kioslave)
    Humm I just did that .....put cd in........click the cd in dolphins places panel ..........go to the .ogg directory .......split pane view......drag a .ogg to ~/ and it gives me .ogg
    this is a upgrade to 11.10 from 11.04 so let me go check the strateup 11.10 install and see what I get thare.
      you are correct in the install that started life as 11.10 (before release) opening the cd in dolphin dose not show the folders Mp3, flack, Ogg ?
      if I fiddle my way threw it I will post what finally did it
      but it wont be soon as the wife has some honey do's for me to do tonight.........
        Thanks, Vinny, I look forward to it
