Problems in oneric: oxygen-gtk not working, mic not working
Plasma 5 look&feel for KDE4: http://kde-look.org/content/show.php...content=166438Tags: None
Re: Problems in oneric: oxygen-gtk not working, mic not working
Ok mic seems to work while some recording application is running.
Oxygen-gtk still not fixed. Any ideas?Plasma 5 look&feel for KDE4: http://kde-look.org/content/show.php...content=166438
And it seems that oxygen-gtk doesn't work with pavucontrol but works with other gtk applications like chromium, firefox, gtk-recordmydesktop etc...
Does anybody else have problem with pavucontrol like on the screenshot in my first post?Plasma 5 look&feel for KDE4: http://kde-look.org/content/show.php...content=166438
Ok, if you are accessing this pavucontrol as root (As I suspect you might be), you have to perform the following steps to get it to work.Originally posted by schnelleAnd it seems that oxygen-gtk doesn't work with pavucontrol but works with other gtk applications like chromium, firefox, gtk-recordmydesktop etc...
This will also help with any gtk app while running as root.
1. sudo -i and enter password
2. cp /home/useraccount/.gtkrc-2.0-kde4 ~
3. ln -s /root/.gtkrc-2.0-kde4 .gtkrc-2.0
Its a good idea to also link .gtkrc-2.0-kde4 to .gtkrc-2.0 in your own home directory.
Try running the application after you do this.
I had some issues with gtk apps while running 11.10 beta also and this fixed them.
Funny, because I have been using this gtk fix for like 5 years... You think the Kubuntu devs would do this automatically by now :-D.
Hope this helps!
Joe
Thanks Joe. I hope this will be fixed in the final release.Plasma 5 look&feel for KDE4: http://kde-look.org/content/show.php...content=166438
Because it could cause applications to be unable to run as root in other desktop environments, I think.
If you are running a gtk application as root, it takes its theme setting from the root directory, and not your home directory; /root is the "home" directory for the gtk theme files for applications run as kdesudo. So to set a theme for gtk applications run as root (i.e. Synaptic) you need to run:
kdesudo gtk-chtheme
or whatever you use to change gtk themes. This will not affect gtk applications run as a user. I use a different theme as root as a reminder.
By the way, you probably should not be running pavaucontrol as root, for roughly the same reason -- pulseaudio setting are (at least by default) configured on a user basis. Unless you have changed things, settings made as root may not apply properly to applications you run as a user.
I didn't run pavucontrol as root.
I reinstalled Oneiric with daily build and this is not fixed. It affects other gtk apps as well: http://www.dodaj.rs/?3p/XO/NioDUSf/snapshot1.jpgPlasma 5 look&feel for KDE4: http://kde-look.org/content/show.php...content=166438
bugreport: https://bugs.launchpad.net/ubuntu/+bug/825858
Vote for oxygen-gtk3 to be packaged
I have had trouble with this also... and gtk fonts.
I have found the best way to overcome this is by using only krunner and not konsole :
kdesu systemsettings and set as you require.
You may need to do this a number of times, change and change back again before it "takes".
IIRC a restart or login helped.
HTHKubuntu 12.04 - Acer Aspire 5750G
"I don't make a great deal of money, but I'm ok with that 'cause I don't hurt a lot of people in the process either"
It isn't exactly a bug; the problem appers only for GTK3 apps, as we don't have oxygen-gtk3(probably will be named gtk3-engines-oxygen) packaged - it isn't officialy released yetsigpic
Uploaded oxygen-gtk3 just now, if anyone wants to test:
https://launchpad.net/~hrvojes/+archive/kde-goodiessigpic
Sorry, I didn't understand if it's fixed or not, nor how to fix it.
Since the upgrade to Kubuntu 11.10, the oxygen-gtk issue affects me too. It doesn't work when I run palimpsest (root or not).
Edit: And I'm having this same issue with Libreoffice: https://bbs.archlinux.org/viewtopic.php?id=121337
