After 3 days and countless attempts I feel comfortable in saying that Natty will not work with a Nvidia Geforce 9500GT when a person tries use the proprietary nvidia drivers. After installing the driver the system will only boot to a command prompt.
I have tried numerous possible solutions only to find failure.
1.) I tried to use the additional drivers app "jockey-kde". After reboot only command prompt.
2.) Then issue the command "sudo nvidia-xconfig". After reboot only command prompt.
reinstall a fresh version of natty
3.) Found the following thread: http://kubuntuforums.net/forums/inde...opic=3107406.0 Attempted to install the proprietary driver manually. Followed the instructions verbatim. After reboot only command prompt.
4.) Used the apt-get tool to install proprietary driver. After reboot only command prompt.
Give up. Concede.
I know folks will want to see a log or actual error output. Unfortunately I cannot copy and paste since I have no gui when the message present themselves. Bottom line is I'm not the only one having issues with my Nvidia card and this release. So I have a simple question, what should I do? Buy a new graphics card? Install 10.10? Wait to see if this problem finds a collective effect and someone fixes? Any suggestions would be appreciated.
Give up. Concede.
