Hello there,
I'm a Kubuntu newbie. I've had Ubuntu before, and decided to give Kubuntu a try. Let's just say my transition to Kubuntu wasn't half as smooth as it was with Ubuntu. I really want to make it work, and I tried to search for a solution on every single issue I had, with not much luck usually. So here goes:
First of all - the fonts! I haven't toyed with the appearance settings, it just how it came "from the box". The title bar font are all very ugly, on GTK and KDE applications alike. I tried to play with the anti-aliasing setting, and it did nothing for me. I installed the MS fonts and the NVIDIA driver, too. Firefox looks extremely horrible, so does Amarok. I searched everywhere, I just can't find any solution to this. The fonts render beautifully on the panel, but that's pretty much the only place they to that.
Now, for the second one. I have a bluetooth MS mouse. It paired with Kubuntu without any problems. But if I reboot, BlueDevil say a PIN is needed to pair with the device. If I try to, it does nothing. If I specifically ask to connect to the mouse, it gets to the window where I can enter PIN, but after I do (either automatically or by entering 0000), it just gets stuck in the PIN validation window. The only way to reconnect the mouse is by removing it and connecting anew, which is a ridiculous and tedious thing to do after each rebooting.
Thanks in advance!
Thanks in advance!
