[INSOLVABLE] Can't unmute sound - Kubuntu freezes
    Hello!
    I did a fresh install from Kubuntu 10.04 to 10.10. Before installation I did this "error check" thing and no errors were found. Installation went smoothly and everything seemed fine. By default, sound is muted. When I try to unmute it, Kubuntu freezes. I've tried to unmute in KMix, pavucontrol (I thought, maybe the problem is in KMix..) and I also tried keyboard shortcuts. It still freezes. Then I installed Kubuntu again, but the problem is still here.
    Help, please..?
    Thank you!
    Re: Can't unmute sound - Kubuntu freezes
    Everytime I have an issue with my sound (always been a Kubuntu user ) I start alsamixer in an terminal to see if there is something muted or not. It might apply here?!
      right click on the kmix icon and be sure you have the correct master channel (sometimes its named wrong) . if that don't work for you output of the command lspci or the multimedia section of lshw would be helpful to see what device you have. you might only have one. you might have two or five. i have found pulse likes to use hdmi as default out a lot of the time sometimes that can be an issue.
      (top of thread: thread tools)
        Well.. I don't know what to look (don't know much about computers...), but the lshw gave this:
        *-multimedia
        description: Audio device
        product: 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller
        vendor: Intel Corporation
        physical id: 1b
        bus info: pci@0000:00:1b.0
        version: 04
        width: 64 bits
        clock: 33MHz
        capabilities: pm msi pciexpress bus_master cap_list
        configuration: driver=HDA Intel latency=0
        resources: irq:16 memory:d0180000-d0183fff
        KMix showed one device - Internal Audio Analog Stereo.
        I started alsamixer in terminal, too. Scrolled everything to maximum - nothing Then pressed "M" (to unmute) - Kubuntu crashed again. Nice.
        I also tried Kubuntu without installing (this option on the CD) and the same problem occurred there, so maybe I should burn a new Kubuntu-CD and install it again..?
          Have you checked "Device Preference" in the "MultiMedia" section of System Settings? I'm not 100% on this, but that may make a difference.
          Andy R.
          Kubuntu 12.10
            Try a different 'backend.' I had earlier issues with sound which were resolved by installing phonon-backend-xine (I have a laptop with an Intel HDA sound chip as well, although different than yours).
            Description: Phonon Xine 1.1.x backend
            Phonon is the Qt 4 multimedia API, which provides a task-oriented abstraction
            layer for capturing, mixing, processing, and playing audio and video content.
            This package contains the Xine 1.1.x backend for Phonon.
            Slava Ukraini! 🇺🇦
              There's nothing I can do in Multimedia -> Device Preference...
              And I already have phonon-backend-xine.
              And as I just discovered that restart option doesn't work, I'll burn a new CD tomorrow, install Kubuntu again and hope it'll work then
              But thanks for trying to help
                So, I downloaded kubuntu, burned a new disk, did a fresh install again - still, can't unmute sound It's unreal!
                  Re: [INSOLVABLE] Can't unmute sound - Kubuntu freezes
                  These instructions are old, but maybe you can get some ideas. In particular, you might be able to upgrade alsa to a newer version?
                  http://kubuntuforums.net/forums/inde...opic=3108441.0
                  Also, I recently bought a usb sound card on Amazon, I think it was about USD $2. I am not sure if you can get these, depending where you live, but sometimes an ultra-cheap gadget can get you going until the dust settles ...
                  Good luck!
                    Thanks! Right now I'm back to Kubuntu 10.04, but when I have time, I give 10.10 another try and let's see if these instructions help
                      I don't quite understand your first post where you write about a 'fresh install' from 10.04 to 10.10.
                      Now you either did a fresh install of 10.10 or you upgraded from 10.04 to 1010, what was it?
                      Because if sound works for you in 10.04 doing an upgrade might give you a different or better experience than a fresh install.
