hers what happen to me. I was doing the upgrade form kpackage kit realized i dint have time. then i had many errors so i ran a sudo dpgk -f i think any want lots of packages update redid themselves i don't know then it asked me if i wanted to go with the new package manger . all seemed good and it asked for a reboot, (i wish i had finished the upgrade before then) my computer sasy i am upgraded to 10,10 but it seems xorg wont load and i don't know what nvida driver i would need. I tried sudo apt-get upgate form the ttyl it sasy no public key then spits out a number . how to i finish the upgrade ? what can i do to get to a place wher all the upgrade go thur grub says i have 10.10 and i cant seem to get a live cd to work.
my machine at ttyl screen [SOLVED READ FOR NVIDIA ISSUES ]
Re: my machine at ttyl screen
will that fix the bootign issue ?Originally posted by StarWolf[quote from othre board]
So, I got rid of the problem by simply removing the /etc/X11/xorg.conf file
[/quote]
this works if you have an issue where the nvidia drivers a broken
oonce i got to the X11 directory i typed (cd .. and cd {dir names}
Sudo rm xorg.conf -f
This fixed the issue
this or a similar post
http://ubuntuforums.org/showthread.php?t=1472067
is where i got my inforamtion, i still ahve 347 updates to process to complete upgrade
Re: my machine at ttyl screen [SOLVED READ FOR NVIDIA ISSUES ]
I had a similar problem when upgrading from 10.04 LTS, but don't seems to be a Nvidia problem.
After GRUB, the Kubuntu splash screen is showed normally.
And, before showing the auth screen, it changes to text mode.
Does anybody else had this problem?
I think it's a Xorg problem.
Below are the /etc/X11/Xorg.conf.d and /var/log/Xorg.0.log file contents, and the lspci output:
/etc/X11/Xorg.conf
/var/log/X11/Xorg.0.logCode:Section "Device" Identifier "Configured Video Device" Driver "fbdev" EndSection Section "Monitor" Identifier "Configured Monitor" EndSection Section "Screen" Identifier "Default Screen" Monitor "Configured Monitor" Device "Configured Video Device" EndSection
LSPCI:Code:[ 41.431] X.Org X Server 1.9.0 Release Date: 2010-08-20 [ 41.431] X Protocol Version 11, Revision 0 [ 41.431] Build Operating System: Linux 2.6.24-27-server i686 Ubuntu [ 41.431] Current Operating System: Linux EG1186342 2.6.35-22-generic #34-Ubuntu SMP Sun Oct 10 09:24:00 UTC 2010 i686 [ 41.432] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.35-22-generic root=UUID=a43561bf-b4de-4124-b90d-850490f16e61 ro quiet splash nomodeset video=uvesafb:mode_option=1280x800-24,mtrr=3,scroll=ywrap [ 41.432] Build Date: 16 September 2010 05:39:22PM [ 41.432] xorg-server 2:1.9.0-0ubuntu7 (For technical support please see [url]http://www.ubuntu.com/support[/url]) [ 41.432] Current version of pixman: 0.18.4 [ 41.432] Before reporting problems, check [url]http://wiki.x.org[/url] to make sure that you have the latest version. [ 41.432] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 41.432] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Oct 16 21:45:07 2010 [ 41.432] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 41.432] (==) No Layout section. Using the first Screen section. [ 41.432] (==) No screen section available. Using defaults. [ 41.432] (**) |-->Screen "Default Screen Section" (0) [ 41.432] (**) | |-->Monitor "<default monitor>" [ 41.432] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 41.432] (==) Automatically adding devices [ 41.432] (==) Automatically enabling devices [ 41.433] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 41.433] Entry deleted from font path. [ 41.433] (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, built-ins [ 41.433] (==) ModulePath set to "/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules" [ 41.433] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 41.433] (II) Loader magic: 0x81f8e00 [ 41.433] (II) Module ABI versions: [ 41.433] X.Org ANSI C Emulation: 0.4 [ 41.433] X.Org Video Driver: 8.0 [ 41.433] X.Org XInput driver : 11.0 [ 41.433] X.Org Server Extension : 4.0 [ 41.434] (--) PCI:*(0:0:2:0) 8086:2a42:103c:30dd rev 7, Mem @ 0xd8000000/4194304, 0xc0000000/268435456, I/O @ 0x00006120/8 [ 41.434] (--) PCI: (0:0:2:1) 8086:2a43:103c:30dd rev 7, Mem @ 0xd8400000/1048576 [ 41.434] (II) Open ACPI successful (/var/run/acpid.socket) [ 41.434] (II) LoadModule: "extmod" [ 41.434] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so [ 41.434] (II) Module extmod: vendor="X.Org Foundation" [ 41.434] compiled for 1.9.0, module version = 1.0.0 [ 41.434] Module class: X.Org Server Extension [ 41.434] ABI class: X.Org Server Extension, version 4.0 [ 41.434] (II) Loading extension MIT-SCREEN-SAVER [ 41.434] (II) Loading extension XFree86-VidModeExtension [ 41.434] (II) Loading extension XFree86-DGA [ 41.434] (II) Loading extension DPMS [ 41.434] (II) Loading extension XVideo [ 41.434] (II) Loading extension XVideo-MotionCompensation [ 41.434] (II) Loading extension X-Resource [ 41.434] (II) LoadModule: "dbe" [ 41.435] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so [ 41.435] (II) Module dbe: vendor="X.Org Foundation" [ 41.435] compiled for 1.9.0, module version = 1.0.0 [ 41.435] Module class: X.Org Server Extension [ 41.435] ABI class: X.Org Server Extension, version 4.0 [ 41.435] (II) Loading extension DOUBLE-BUFFER [ 41.435] (II) LoadModule: "glx" [ 41.435] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 41.435] (II) Module glx: vendor="X.Org Foundation" [ 41.435] compiled for 1.9.0, module version = 1.0.0 [ 41.435] ABI class: X.Org Server Extension, version 4.0 [ 41.435] (==) AIGLX enabled [ 41.435] (II) Loading extension GLX [ 41.435] (II) LoadModule: "record" [ 41.436] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so [ 41.436] (II) Module record: vendor="X.Org Foundation" [ 41.436] compiled for 1.9.0, module version = 1.13.0 [ 41.436] Module class: X.Org Server Extension [ 41.436] ABI class: X.Org Server Extension, version 4.0 [ 41.436] (II) Loading extension RECORD [ 41.436] (II) LoadModule: "dri" [ 41.436] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so [ 41.436] (II) Module dri: vendor="X.Org Foundation" [ 41.436] compiled for 1.9.0, module version = 1.0.0 [ 41.436] ABI class: X.Org Server Extension, version 4.0 [ 41.436] (II) Loading extension XFree86-DRI [ 41.436] (II) LoadModule: "dri2" [ 41.436] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so [ 41.436] (II) Module dri2: vendor="X.Org Foundation" [ 41.436] compiled for 1.9.0, module version = 1.2.0 [ 41.436] ABI class: X.Org Server Extension, version 4.0 [ 41.437] (II) Loading extension DRI2 [ 41.437] (==) Matched intel as autoconfigured driver 0 [ 41.437] (==) Matched vesa as autoconfigured driver 1 [ 41.437] (==) Matched fbdev as autoconfigured driver 2 [ 41.437] (==) Assigned the driver to the xf86ConfigLayout [ 41.437] (II) LoadModule: "intel" [ 41.437] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so [ 41.437] (II) Module intel: vendor="X.Org Foundation" [ 41.437] compiled for 1.9.0, module version = 2.12.0 [ 41.437] Module class: X.Org Video Driver [ 41.437] ABI class: X.Org Video Driver, version 8.0 [ 41.437] (II) LoadModule: "vesa" [ 41.437] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so [ 41.437] (II) Module vesa: vendor="X.Org Foundation" [ 41.437] compiled for 1.8.99.905, module version = 2.3.0 [ 41.437] Module class: X.Org Video Driver [ 41.437] ABI class: X.Org Video Driver, version 8.0 [ 41.437] (II) LoadModule: "fbdev" [ 41.437] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 41.437] (II) Module fbdev: vendor="X.Org Foundation" [ 41.437] compiled for 1.8.99.905, module version = 0.4.2 [ 41.437] ABI class: X.Org Video Driver, version 8.0 [ 41.437] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810, i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45, 4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale, Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge [ 41.438] (II) VESA: driver for VESA chipsets: vesa [ 41.438] (II) FBDEV: driver for framebuffer: fbdev [ 41.438] (++) using VT number 7 [ 41.441] (WW) Falling back to old probe method for vesa [ 41.441] (WW) Falling back to old probe method for fbdev [ 41.441] (II) Loading sub module "fbdevhw" [ 41.441] (II) LoadModule: "fbdevhw" [ 41.441] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 41.441] (II) Module fbdevhw: vendor="X.Org Foundation" [ 41.441] compiled for 1.9.0, module version = 0.0.2 [ 41.441] ABI class: X.Org Video Driver, version 8.0 [ 41.445] (EE) intel(0): No kernel modesetting driver detected. [ 41.445] (II) UnloadModule: "intel" [ 41.445] (EE) Screen(s) found, but none have a usable configuration. [ 41.445] Fatal server error: [ 41.445] no screens found [ 41.445] Please consult the The X.Org Foundation support at [url]http://wiki.x.org[/url] for help. [ 41.445] Please also check the log file at "/var/log/Xorg.0.log" for additional information. [ 41.445] [ 41.532] ddxSigGiveUp: Closing log
Code:00:00.0 "Host bridge" "Intel Corporation" "Mobile 4 Series Chipset Memory Controller Hub" -r07 "Hewlett-Packard Company" "Device 30dd" 00:02.0 "VGA compatible controller" "Intel Corporation" "Mobile 4 Series Chipset Integrated Graphics Controller" -r07 "Hewlett-Packard Company" "Device 30dd" 00:02.1 "Display controller" "Intel Corporation" "Mobile 4 Series Chipset Integrated Graphics Controller" -r07 "Hewlett-Packard Company" "Device 30dd" 00:1a.0 "USB Controller" "Intel Corporation" "82801I (ICH9 Family) USB UHCI Controller #4" -r03 "Hewlett-Packard Company" "Device 30dd" 00:1a.1 "USB Controller" "Intel Corporation" "82801I (ICH9 Family) USB UHCI Controller #5" -r03 "Hewlett-Packard Company" "Device 30dd" 00:1a.2 "USB Controller" "Intel Corporation" "82801I (ICH9 Family) USB UHCI Controller #6" -r03 "Hewlett-Packard Company" "Device 30dd" 00:1a.7 "USB Controller" "Intel Corporation" "82801I (ICH9 Family) USB2 EHCI Controller #2" -r03 -p20 "Hewlett-Packard Company" "Device 30dd" 00:1b.0 "Audio device" "Intel Corporation" "82801I (ICH9 Family) HD Audio Controller" -r03 "Hewlett-Packard Company" "Device 30dd" 00:1c.0 "PCI bridge" "Intel Corporation" "82801I (ICH9 Family) PCI Express Port 1" -r03 "" "" 00:1c.1 "PCI bridge" "Intel Corporation" "82801I (ICH9 Family) PCI Express Port 2" -r03 "" "" 00:1c.2 "PCI bridge" "Intel Corporation" "82801I (ICH9 Family) PCI Express Port 3" -r03 "" "" 00:1c.4 "PCI bridge" "Intel Corporation" "82801I (ICH9 Family) PCI Express Port 5" -r03 "" "" 00:1c.5 "PCI bridge" "Intel Corporation" "82801I (ICH9 Family) PCI Express Port 6" -r03 "" "" 00:1d.0 "USB Controller" "Intel Corporation" "82801I (ICH9 Family) USB UHCI Controller #1" -r03 "Hewlett-Packard Company" "Device 30dd" 00:1d.1 "USB Controller" "Intel Corporation" "82801I (ICH9 Family) USB UHCI Controller #2" -r03 "Hewlett-Packard Company" "Device 30dd" 00:1d.2 "USB Controller" "Intel Corporation" "82801I (ICH9 Family) USB UHCI Controller #3" -r03 "Hewlett-Packard Company" "Device 30dd" 00:1d.7 "USB Controller" "Intel Corporation" "82801I (ICH9 Family) USB2 EHCI Controller #1" -r03 -p20 "Hewlett-Packard Company" "Device 30dd" 00:1e.0 "PCI bridge" "Intel Corporation" "82801 Mobile PCI Bridge" -r93 -p01 "" "" 00:1f.0 "ISA bridge" "Intel Corporation" "ICH9M LPC Interface Controller" -r03 "Hewlett-Packard Company" "Device 30dd" 00:1f.2 "IDE interface" "Intel Corporation" "ICH9M/M-E 2 port SATA IDE Controller" -r03 -p8a "Hewlett-Packard Company" "Device 30dd" 00:1f.5 "IDE interface" "Intel Corporation" "ICH9M/M-E 2 port SATA IDE Controller" -r03 -p85 "Hewlett-Packard Company" "Device 30dd" 02:00.0 "Network controller" "Intel Corporation" "PRO/Wireless 5100 AGN [Shiloh] Network Connection" "Intel Corporation" "WiFi Link 5100 AGN" 85:00.0 "Ethernet controller" "Broadcom Corporation" "NetLink BCM5787M Gigabit Ethernet PCI Express" -r02 "Hewlett-Packard Company" "Device 30dd" 86:02.0 "FireWire (IEEE 1394)" "Agere Systems" "FW322/323" -r70 -p10 "Hewlett-Packard Company" "Device 30dd"
try reinstalling nvidia driver. lots of stuff gets messed up when upgrading.Home: Kubuntu 12.04-amd64; Intel i7-860 on Intel DH55PJ; Nvidia 9500GT; 6GB RAM
Network Slave: Xubuntu 11.10-x86; Intel P4-Prescott on MSI; 2GB RAM; Nvidia FX5200
Portable: Xubuntu 11.10-amd64; Asus EeePC 1015PEM
