Audio problem
    Audio problem
    Hey,
    I am having trouble with Kubuntu. I just switched over from Ubuntu, and when I logon, I hear bits of sound. Then when I try to play a youtube video, it goes like its in fast forward mode. I'm not very good with Kubuntu, so I would like some help on how to fix this. Thanks!
    Re: Audio problem
    We need to know about your PC and the hardware. Specifically, the sound card/chip.
    Open a console and type:
    lspci | grep udio
    Copy/paste the results.
      Re: Audio problem
      kevin@kevin-desktop:~$ lspci | grep udio
      02:02.0 Multimedia audio controller: Creative Labs [SB Live! Value] EMU10k1X
        Re: Audio problem
        Have you checked K > System > Additional Drivers to see if anything is identified for your sound card?
          Re: Audio problem
          I just did. It shows that nothing needs to be installed for additional drivers.
            Re: Audio problem
            What does:
            modprobe -l snd-emu*
            show?
              Re: Audio problem
              kevin@kevin-desktop:~$ modprobe -l snd-emu*
              kernel/sound/isa/sb/snd-emu8000-synth.ko
              kernel/sound/pci/emu10k1/snd-emu10k1.ko
              kernel/sound/pci/emu10k1/snd-emu10k1-synth.ko
              kernel/sound/pci/emu10k1/snd-emu10k1x.ko
              kernel/sound/synth/emux/snd-emux-synth.ko
                Re: Audio problem
                Okay, the module is there (kernel/sound/pci/emu10k1/snd-emu10k1x.ko).
                As to multimedia, what is listed in K > System Settings > Mulitimedia for Sound and Video Configuration (mine is Phonon), and when on that, what is identified as the Backend?
                  Re: Audio problem
                  Xine
                    Re: Audio problem
                    Do you get any proper sounds at all, say from regular video or music files?
                    http://ubuntuforums.org/showthread.php?t=1592093
                    https://bugs.launchpad.net/ubuntu/+s...ux/+bug/663876
                    I don't see a kubuntu based solution, though there should be a way to try to change the setting.
                      Re: Audio problem
                      In Konsole:
                      sudo apt-get update && sudo apt-get install paman padevchooser pavucontrol
                      When they are installed, close the konsole.
                      Alt-F2 "pavucontrol" with no quote marks. Click the tabs for Configuration and Output Devices, and make sure nothing is muted, and the devices look appropriate to your hardware.
                      In System Settings > Multimedia, highlight the top device and click the "test" button at the bottom of the pane. Do you hear the music?
                        Re: Audio problem
                        claydoh: No I don't, I tried playing my music I have on here, and it didn't work.
                        dibl: I did that, and it still doesn't work.
                          Re: Audio problem
                          Doesn't work how? pavucontrol doesn't show devices? System-settings "test" doesn't output sound?
                          BTW, you don't happen to also have an onboard sound chip, do you?
                            Re: Audio problem
                            It shows devices, but they're not muted. And I tried that, and like, sound comes, but its in bits, and then it goes away. I didn't have this problem with Ubuntu, I don't see why I would have it now?
                              Re: Audio problem
                              Run
                              lspci -vv
                              and post the full output.
