I have a problem on playing some video
    Another option
    There is an option to have both the ffmpeg and the libav in the same system.
    :~$ ffmpeg -version
    ffmpeg version 0.8.6-6:0.8.6-1ubuntu2, Copyright (c) 2000-2013 the Libav developers
    built on Mar 30 2013 22:20:06 with gcc 4.7.2
    *** THIS PROGRAM IS DEPRECATED ***
    This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
    ffmpeg 0.8.6-6:0.8.6-1ubuntu2
    libavutil 51. 22. 1 / 51. 22. 1
    libavcodec 53. 35. 0 / 53. 35. 0
    libavformat 53. 21. 1 / 53. 21. 1
    libavdevice 53. 2. 0 / 53. 2. 0
    libavfilter 2. 15. 0 / 2. 15. 0
    libswscale 2. 1. 0 / 2. 2.100
    libpostproc 52. 0. 0 / 52. 2.100
    The ffmpeg and the ffmpeg libraries are in the /opt/...
    :~$ /opt/ffmpeg/bin/ffmpeg -version
    ffmpeg version 1.2
    built on Apr 20 2013 17:28:55 with gcc 4.7 (Ubuntu/Linaro 4.7.3-1ubuntu1)
    configuration: --prefix=/opt/ffmpeg --libdir=/opt/ffmpeg/lib/ --enable-shared --disable-stripping --enable-gpl --enable-version3 --enable-runtime-cpudetect --enable-postproc --enable-x11grab --enable-libcdio --enable-vaapi --enable-vdpau --enable-bzlib --enable-gnutls --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-libfreetype --enable-libpulse
    libavutil 52. 18.100 / 52. 18.100
    libavcodec 54. 92.100 / 54. 92.100
    libavformat 54. 63.104 / 54. 63.104
    libavdevice 54. 3.103 / 54. 3.103
    libavfilter 3. 42.103 / 3. 42.103
    libswscale 2. 2.100 / 2. 2.100
    libswresample 0. 17.102 / 0. 17.102
    libpostproc 52. 2.100 / 52. 2.100
    The real ffmpeg doesn't have the problem with the "Different bit depth between chroma and luma" /3/.
    The Qmplay2 /1, 2/ (with the ffmpeg) is playing the example clip without problems.
    Tested - It is possible to compile the VLC with the ffmpeg in the /opt/-> working VLC with the example clip.
    The VLC & libav from the Oneiric (Ubuntu 11.10) can play the example clip without problems /3/.
    Links:
    1. http://www.kubuntuforums.net/showthr...l=1#post311066
    2. http://www.kubuntuforums.net/showthr...er-application
    3. The libav is telling:
    Different bit depth between chroma and luma not implemented. Update your Libav version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
    If you want to help, upload a sample of this file to ftp://upload.libav.org/incoming/ and contact the libav-devel mailing list.
    LIbav: http://libav.org/
    h264: check for luma and chroma bit depth being equal (CVE-2013-2277)
    The CVE-2013-2277: http://people.canonical.com/~ubuntu-...2013-2277.html
    The ff_h264_decode_seq_parameter_set function in h264_ps.c in libavcodec in
    FFmpeg before 1.1.3 does not validate the relationship between luma depth
    and chroma depth, which allows remote attackers to cause a denial of
    service (out-of-bounds array access and application crash) or possibly have
    unspecified other impact via crafted H.264 data.
    Ubuntu bugs: https://bugs.launchpad.net/ubuntu/+s...v/+bug/1163354
    Before you edit, BACKUP !
    Why there are dead links ?
    2. Thread: Lost Information
