Results 1 to 3 of 3
Thread: Need help with shared directory /not networked/
  1. Back To Top    #1
    Newbie
    Join Date
    May 2014
    Posts
    5
    Threads
    2
    Local Date
    Jun 5th 2020
    Local Time
    11:26 AM
    I'm trying to create a simple shared directory on a Kubuntu 18.04 computer which my wife and I both use. I followed the instructions at www.tecmint.com/create-a-shared-directory-in-linux/ which seem representative of the solutions that I found Googling the question. The general idea is to create a group, add users to it, create a directory, set the directory group, and set tyhe directory group ID sticky. I tried it first with a new directory in /home but couldn't write files to it. I eventually resorted to cut'n'pasting the exact commands, file locations and group names from the example. Still no luck. The only way I can use the directory is if I change the owner of the directory from root to my own user name. Not too useful. I tried another similar set of instructions and it failed, too.
    What am I doing wrong?
    Image of console output attached.
  2. Back To Top    #2
    Emergent AI kubicle's Avatar
    Join Date
    Dec 2005
    Posts
    4,693
    Threads
    90
    Local Date
    Jun 5th 2020
    Local Time
    06:26 PM
    Have you relogged/rebooted after adding the users to the group "project", group adds don't take effect instantaneously (for currently logged in users)
  3. Back To Top    #3
    Newbie
    Join Date
    May 2014
    Posts
    5
    Threads
    2
    Local Date
    Jun 5th 2020
    Local Time
    11:26 AM
    I did not know that. And everything is working fine this morning. If you hadn't commented, I would have thought I was going nuts.
    Thank you.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
