Results 1 to 7 of 7
Thread: Plasmashell not starting at booting the system
  1. Back To Top    #1
    Contributing Member
    Join Date
    Oct 2016
    Location
    Ottobrunn, Germany
    Posts
    33
    Threads
    10
    Local Date
    Jun 3rd 2020
    Local Time
    04:51 AM
    Hello everybody,
    After completing all the available updates yesterday I noticed that suddenly some of the applications, such as krunner wouldn't work anymore and others could not be terminated anymore. As the shutdown app did not work either, I had to use the shutdown shell command to terminate Kubuntu. Today, when I tried to start up the system, the booting procedure stopped during displaying the kubuntu logo but did not go on into the login screen. Watching the booting procedure in the command line mode does not show any errors. after the line saying something like ...user-session... the screen is cleared. Entering the command line mode again, I can login as usual. However, if I tra to strart PlasmaShell, I get the following error:
    peter@T5300: ~/kstart5 plasmashell
    qt.qpa.xcb: could not connect to display
    qt.qta.plugin: could not load the Qt platform plugin "xcb" in "" even though it was found.
    This application failed to start because not Qt platform plugin could be initialized. reinstalling the app may fix this problem
    Available platform plugins are: wayland-org.kde.kwin.qpa, eglfs, ...
    fish: 'kstart5 plasmashell' terminated by signal SIGABRT (Abbruch)
    Reinstalling xcb did not fix anything.
    Running any apt-get command lists a huge number of lib packages, which obvouosly are marked as 'no longer required and can be removed', which I did not do, of course, as this seems rather strange to me.
    Does anybody have a suggestion, how I can get my Plasma Desktop up and running again? Any help would be highly appreciated.
    Edit 1: Using startx I get a (probably gnome-shell) desktop. switching to plasmashell works but most of the destop functions are not working. Also, the display configuration in the system settings is not available. Any ideas?
    Edit 2: Currently running
    Kubuntu 19.10
    plasma-desktop 5.18.0
    Qt 5.12.4
    KDE Frameworks 5.67.0
    Kf5-config 1.0
  2. Back To Top    #2
    Contributing Member
    Join Date
    Oct 2016
    Location
    Ottobrunn, Germany
    Posts
    33
    Threads
    10
    Local Date
    Jun 3rd 2020
    Local Time
    04:51 AM
    After the number of problems increased, I decided to do a fresh install and moved to Neon User Editon, which fixed all issues I had.
    Thanks to eveybody.
  3. Back To Top    #3
    Ascendant Snowhog's Avatar
    Join Date
    Mar 2007
    Location
    Columbia Heights, MN
    Posts
    20,596
    Threads
    1012
    Local Date
    Jun 2nd 2020
    Local Time
    10:51 PM
    Well, it might have been telling, given you did a fresh install a new, if you had done so with a freshly downloaded copy of 19.10, installing and formatting root and home. Won't know now.
    Twin Cities Bicycling Club - "And miles to go before I sleep."
  4. Back To Top    #4
    Contributing Member
    Join Date
    Oct 2016
    Location
    Ottobrunn, Germany
    Posts
    33
    Threads
    10
    Local Date
    Jun 3rd 2020
    Local Time
    04:51 AM
    Wel, I am sure a fresh install of 19.10 would have worked well, too. However, I don't think it would have been telling in any way, as i had installed so many applications with a lot of customizing before that it would have been practically impossible to establish the same system configuration again. i guess, it was my messing around with the system, which lead to that 'unhealthy' status, and which I was not able to roll back again.
    Thanks, anyway.
  5. Back To Top    #5
    Join Date
    Mar 2007
    Location
    Posts
    20,596
    Threads
    1012
    Local Date
    Jun 2nd 2020
    Local Time
    10:51 PM
    Understand, and totally agree. I don't know if you do, but if you don't, and you are willing, start keeping a log of all changes "you" introduce to your system; adding of PPAs, installing downloaded software (.deb files), etc. It is a huge help when something with you system suddenly goes awry.
  6. Back To Top    #6
    Ascendant GreyGeek's Avatar
    Join Date
    Feb 2009
    Posts
    16,480
    Threads
    1169
    Local Date
    Jun 2nd 2020
    Local Time
    10:51 PM
    You can't go wrong with Neon User Edition, BUT, regardless of which distro release you use, keeping regular backups of your system is essential. IF you are running EXT4 then I'd recommend installing TimeShift and set it to automatic regular backups. If you run into other problems which you can't immediately resolve then restoring from the last backup before any changes that created problems would return you to a functioning system. Then, before you do any updates, PPA's for non-repository installs you can weed through them to see what caused your problems.
  7. Back To Top    #7
    Contributing Member
    Join Date
    Oct 2016
    Location
    Ottobrunn, Germany
    Posts
    33
    Threads
    10
    Local Date
    Jun 3rd 2020
    Local Time
    04:51 AM
    I am using the bup backup tool of the systemsettings but I only stored the Home volume. Might be good idea to include atleast some of the root directories into the backup.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
