Realtek driver r8169 slow network speed
    Now I use kubuntu 18.04 and used ubuntu 16.04 before, the same problem.
    On linux the speed is 10Mb/s but on Windows 7 (dual boot) the speed of the link is 100Mb/s.
    I read a couple of posts about my network interface issues with slow speed, nothing to help.
    Info :
    [COLOR=#222222][FONT=monospace][COLOR=#000000]sudo lshw -C network         [/COLOR]
     *-network
          description: Ethernet interface
          product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
          vendor: Realtek Semiconductor Co., Ltd.
          physical id: 0
          bus info: pci@0000:05:00.0
          logical name: enp5s0
          version: 06
          serial: 4c:cc:6a:61:bf:a8
          capacity: 1Gbit/s
          width: 64 bits
          clock: 33MHz
          capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
          configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.21.46 latency=0 link=yes mul
    ticast=yes port=MII speed=100Mbit/s
          resources: irq:16 ioport:d000(size=256) memory:fe704000-fe704fff memory:fe700000-fe703fff
    [/FONT][/COLOR][COLOR=#222222][FONT=Verdana][/FONT][/COLOR]
    [COLOR=#222222][FONT=monospace][COLOR=#000000]lsmod | grep r81[/COLOR]
    [COLOR=#FF5454][B]r81[/B][/COLOR][COLOR=#000000]69                  86016  0[/COLOR]
    mii        [/FONT][/COLOR][COLOR=#222222][FONT=Verdana] [/FONT][/COLOR][COLOR=#222222][FONT=monospace]           16384  1 [COLOR=#FF5454][B]r81[/B][/COLOR][COLOR=#000000]69[/COLOR]
    [COLOR=#222222][FONT=monospace][COLOR=#000000]sudo ethtool enp5s0[/COLOR]
    Settings for enp5s0:
           Supported ports: [ TP MII ]
           Supported link modes:   10baseT/Half 10baseT/Full
                                   100baseT/Half 100baseT/Full
                                   1000baseT/Half 1000baseT/Full
           Supported pause frame use: No
           Supports auto-negotiation: Yes
           Supported FEC modes: Not reported
           Advertised link modes:  10baseT/Half 10baseT/Full
           Advertised pause frame use: Symmetric Receive-only
           Advertised auto-negotiation: Yes
           Advertised FEC modes: Not reported
           Link partner advertised link modes:  10baseT/Half 10baseT/Full
           Link partner advertised pause frame use: Symmetric
           Link partner advertised auto-negotiation: Yes
           Link partner advertised FEC modes: Not reported
           Speed: 100Mb/s
           Duplex: Full
           Port: MII
           PHYAD: 0
           Transceiver: internal
           Auto-negotiation: on
           Supports Wake-on: pumbg
           Wake-on: g
           Current message level: 0x00000033 (51)
                                  drv probe ifdown ifup
           Link detected: yes
    I have a similar problem, for me it's 100MB on windows and 20MB on Kubuntu. See my post
    https://www.kubuntuforums.net/showth...fer-speed-slow
      I am in the same boat with a wifi driver. How about booting a disti with more recent kernel and drivers to see if this is maybe already fixed somewhere else? Didn't work for me but maybe it helps you. Don't bother with the Kubuntu 19.04 beta, that kernel is the same or older than what you got.I used Manjaro.
        I have a suspicion it's a Dolphin problem. My disk to disk transfers, within the same box are also significantly slower than expected at around 40mb/s. I have another Ubuntu machine that does not have this issue which has the same kernel as Kubuntu..
          I did further investigation into this by doing comparisons between Dolphin, Konqueror and Nautilus from my PC. In general terms Konqueror was twice as fast while Nautilus was up to 5 times faster, ie it would transfer at the expected 100 MiB/s. If you are interested I opened a bug https://bugs.kde.org/show_bug.cgi?id=402276
