USB screw ups
    [SOLVED] USB screw ups
    Dell Optiplex 990
    Kubuntu 18.04
    I have front USB plugins and rear USB plugins.
    Something has gone wrong.
    I can't get Dolphin to recognize USB devices that I plug in to any of the ports.
    When it does recognize them it will not allow me to copy files to them.
    This is the same computer I have used for previous versions of Kubuntu, XP, and Win7
    Never had a problem before 18.04.
    All my USB devices work fine on XP and Win7.
    This is making me crazy.
    Can someone please help
    Greg
    W9WD
    Have you opened up the case recently?
      Run Konsole. With the konsole window open, insert a USB device into any of the available USB ports, then in the konsole, type: dmesg | tail -20
      Copy/paste the output in a reply.
        Thank you
        greg@greg-OptiPlex-990:~$ dmesg | tail -20
        [28624.374245] NVRM: No NVIDIA graphics adapter found!
        [28624.374315] nvidia-nvlink: Unregistered the Nvlink Core, major device number 238
        [28624.423234] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
        [28624.423432] NVRM: No NVIDIA graphics adapter found!
        [28624.423503] nvidia-nvlink: Unregistered the Nvlink Core, major device number 238
        [28624.578207] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
        [28624.578419] NVRM: No NVIDIA graphics adapter found!
        [28624.578491] nvidia-nvlink: Unregistered the Nvlink Core, major device number 238
        [28624.635675] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
        [28624.635886] NVRM: No NVIDIA graphics adapter found!
        [28624.635955] nvidia-nvlink: Unregistered the Nvlink Core, major device number 238
        [28624.695682] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
        [28624.695892] NVRM: No NVIDIA graphics adapter found!
        [28624.695963] nvidia-nvlink: Unregistered the Nvlink Core, major device number 238
        [28624.765719] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
        [28624.765910] NVRM: No NVIDIA graphics adapter found!
        [28624.765978] nvidia-nvlink: Unregistered the Nvlink Core, major device number 238
        [28624.818699] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
        [28624.818896] NVRM: No NVIDIA graphics adapter found!
        [28624.818966] nvidia-nvlink: Unregistered the Nvlink Core, major device number 238
        Greg
        W9WD
          I removed all the Nvidia drivers I could and reran the command. It says
          [ 72.197952] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
          [ 225.845905] usb 2-1.3.1: USB disconnect, device number 6
          [ 236.820410] usb 2-1.3.1: new high-speed USB device number 7 using ehci-pci
          [ 237.427088] usb 2-1.3.1: New USB device found, idVendor=154b, idProduct=0059
          [ 237.427090] usb 2-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [ 237.427092] usb 2-1.3.1: Product: USB 2.0 FD
          [ 237.427093] usb 2-1.3.1: Manufacturer: PNY Technologies
          [ 237.427094] usb 2-1.3.1: SerialNumber: AC88HCC1000000367
          [ 237.427393] usb-storage 2-1.3.1:1.0: USB Mass Storage device detected
          [ 237.427529] scsi host7: usb-storage 2-1.3.1:1.0
          [ 238.798258] scsi 7:0:0:0: Direct-Access PNY USB 2.0 FD 4096 PQ: 0 ANSI: 4
          [ 238.798861] sd 7:0:0:0: Attached scsi generic sg3 type 0
          [ 238.799471] sd 7:0:0:0: [sdc] 7913472 512-byte logical blocks: (4.05 GB/3.77 GiB)
          [ 238.800319] sd 7:0:0:0: [sdc] Write Protect is off
          [ 238.800320] sd 7:0:0:0: [sdc] Mode Sense: 43 00 00 00
          [ 238.801195] sd 7:0:0:0: [sdc] No Caching mode page found
          [ 238.801198] sd 7:0:0:0: [sdc] Assuming drive cache: write through
          [ 238.805351] sdc: sdc1
          [ 238.808195] sd 7:0:0:0: [sdc] Attached SCSI removable disk
          [ 239.092958] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
          Greg
          W9WD
            It recognizes thumb drives and my camera chip quickly now, but will not allow me to copy files to either?
            Greg
            W9WD
              See this: https://www.tecmint.com/fsck-repair-...rors-in-linux/
              Please review it first. Then review it again. Ask questions here if in doubt about ANYTHING. DON'T do anything until you fully understand.
                I think I will do a clonezilla clone first and then try it.
                Maybe I'll try it on the clone disk first.
                Greg
                W9WD
                  It seems like running fsck would be the easiest upon system boot.
                  A question they don't answer...
                  "After your system boots, check if the file still exists:"
                  "If it does, you may want to remove it in order to avoid fsck on every system boot."
                  What would be the command to remove it?
                  Greg
                  W9WD
                    That concern would only be relevant IF you had to run fsck on the root file system. That isn't your case.
                      I certainly won't argue with you but it does say to remove it...
                      Greg
                      W9WD
                        Remove it "IF" you created it. If you didn't follow the steps under Force fsck Upon System Boot, then nothing to remove.
                          IF it exists, then from a konsole: sudo rm /forcefsck
                            Perfect.
                            Thanks
                            I have my clone made (I'm om it now) and I will give the Force fsck Upon System Boot a whirl.
                            Greg
                            W9WD
                              I guess I'm not doing something right.
                              I copied the command # touch /forcefsck in to the terminal.
                              Rebooted and nothing seemed to happen.
                              Then to check I copied # ls /forcefsck in to the terminal and it returned nothing.
                              What did I do wrong?
                              Greg
                              W9WD
