No audio volume
    Originally posted by M@GO LoBEL View Post
    It is a good idea to put this on The Kubuntu website under the known problems, so people can avoid it.
    Added that on the release notes last night.
    https://wiki.ubuntu.com/ArtfulAardva...Known_Problems
      Originally posted by corwin78 View Post
      I can confirm, that commenting mentioned lines in /etc/pulse/default.pa fixed problem on my ThinkPad W520.
      Weird, I use a W520 and did not get audio problems (clean install, not an upgrade).
        Same problem, same symptoms; commenting the recommended lines did the trick. Thanks, guys!
          Me too. Thank you very much.
            Ok I had the same problem: no audio after installing 17.10. Also, Windows complained when I booted in vbox - no driver or some such.
            Did some googling and reading and trouble shooting.
            Eliminated a h/w problem.
            So s/w.
            Finally I found that this is a known problem in Kubuntu 17.10. Turns out it's a configuration/timing problem and the sequence in which modules are loaded and a module is antiquated and some want to drop it, but others need it, etc, etc, etc. The developers were/are discussing who/what/when.
            One bright soul found a solution with the system as is: https://bugs.launchpad.net/ubuntu/+s...o/+bug/1720519
            To quote him"
            I removed alsa and pulseaudio and reinstalled like this:
            sudo apt-get remove --purge alsa-base pulseaudio
            Now install again Alsa and Pulse Audio:
            sudo apt-get install alsa-base pulseaudio
            Then, reload Alsa:
            sudo alsa force-reload
            Tried it and it worked fine. He also had to remove discord for skype and gamers (not a concern for me) and then it worked over a reboot also.
            I haven't rebooted yet, if it persists maybe I'll write a script to do what he found and leave it at that and hope that the developers can agree on a solution by 18.04. They have a little over 3 months after all.
            Ok - next day and booted this morning and tested sound. Sound ok. So the posted solution persists through a reboot.
