Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: No audio volume
  1. Back To Top    #1
    Contributing Member
    Join Date
    Nov 2007
    Posts
    66
    Threads
    16
    Local Date
    Jan 10th 2018
    Local Time
    07:20 AM
    Angry No audio volume
    I installed Kubuntu 17.10 on my intel desktop and on my Acer laptop today. I noticed that there is no audio volume and it says "No Output or Input Devices Found" on both computers. The audio volume worked on both computers with Kubuntu 17.04. Does any one else have this problem?
  2. Back To Top    #2
    Ancient vinnywright's Avatar
    Join Date
    Apr 2009
    Posts
    7,195
    Threads
    150
    Local Date
    Jan 10th 2018
    Local Time
    12:20 PM
    no ,,,not @hear , but I did a "do-release-upgrade -d" from a working 17.04
    what dose
    pactl list sources
    show .
    and did you check "rite click a blank space in the system tray>click system tray settings>and make sure audio volume is checked.
    system76 Bonox8
  3. Back To Top    #3
    Contributing Member
    Join Date
    Nov 2007
    Posts
    66
    Threads
    16
    Local Date
    Jan 10th 2018
    Local Time
    07:20 AM
    Yes, the audio volume is checked.
  4. Back To Top    #4
    Contributing Member
    Join Date
    Nov 2007
    Posts
    66
    Threads
    16
    Local Date
    Jan 10th 2018
    Local Time
    07:20 AM
    If I click on application launcher, multimedia, volume control, I get a message that says: connection to pulse audio failed because pulse_server in the enviroment x11 root window properties or default-server is mis-configured. Then it says that this can also arrise when the pulse server has crashed.
  5. Back To Top    #5
    Contributing Member
    Join Date
    Oct 2006
    Posts
    29
    Threads
    5
    Local Date
    Jan 10th 2018
    Local Time
    12:20 PM
    I'm having this problem too. Same messages people above are getting. Apparently Pulseaudio is refusing to load. On the terminal, I can type alsamixer and it recognize my soundcards (integrated, HDMI and a USB Asus Xonar U5).
    Typing "pulseaudio" on the terminal gives me this:
    clesio@HAL9004:~$ pulseaudio
    E: [pulseaudio] module.c: Module "module-switch-on-connect" should be loaded once at most. Refusing to load.
    E: [pulseaudio] main.c: Module load failed.
    E: [pulseaudio] main.c: Fail to load daemon.
    If you find a grammar error in my text, is because English is not my native language :-)
  6. Back To Top    #6
    Ascendant GreyGeek's Avatar
    Join Date
    Feb 2009
    Location
    Lincoln, NE
    Posts
    13,723
    Threads
    978
    Local Date
    Jan 10th 2018
    Local Time
    06:20 AM
    Have you tried doing a re-install of pulseaudio?
    There is no truth in the news, and no news in the truth.
  7. Back To Top    #7
    Junior Member corwin78's Avatar
    Join Date
    Oct 2010
    Location
    Ostrava, Czech Republic
    Posts
    19
    Threads
    4
    Local Date
    Jan 10th 2018
    Local Time
    07:20 PM
    Hi guys, I am lost audio after upgrade from 17.04 to 17.10 as well. In settings is only some Default device.
    $ pulseaudio
    W: [pulseaudio] module.c: module-combine is deprecated: Please use module-combine-sink instead of module-combine!
    W: [pulseaudio] module-combine.c: We will now load module-combine-sink. Please make sure to remove module-combine from your configuration.
  8. Back To Top    #8
    Newbie
    Join Date
    Oct 2017
    Posts
    1
    Threads
    0
    Local Date
    Jan 10th 2018
    Local Time
    12:20 PM
    Same problem after upgrading from 17.04 on Dell XPS13-9343.
    In system settings I found that I could not start the hardware detection.
    I tried to install every hardware driver for soundcards that looked good via synaptics and installed alsa, without any effect.
    hwinfo --sound
    09: PCI 03.0: 0403 Audio device
    [Created at pci.378]
    Unique ID: 3hqH.Vb8yTZ1S3x1
    SysFS ID: /devices/pci0000:00/0000:00:03.0
    SysFS BusID: 0000:00:03.0
    Hardware Class: sound
    Model: "Intel Broadwell-U Audio Controller"
    Vendor: pci 0x8086 "Intel Corporation"
    Device: pci 0x160c "Broadwell-U Audio Controller"
    SubVendor: pci 0x1028 "Dell"
    SubDevice: pci 0x0665
    Revision: 0x09
    Driver: "snd_hda_intel"
    Driver Modules: "snd_hda_intel"
    Memory Range: 0xf741c000-0xf741ffff (rw,non-prefetchable)
    IRQ: 50 (657 events)
    Module Alias: "pci:v00008086d0000160Csv00001028sd00000665bc04sc0 3i00"
    Driver Info #0:
    Driver Status: snd_hda_intel is active
    Driver Activation Cmd: "modprobe snd_hda_intel"
    Config Status: cfg=new, avail=yes, need=no, active=unknown
    21: PCI 1b.0: 0403 Audio device
    Unique ID: u1Nb.Zacx4cfNPj4
    SysFS ID: /devices/pci0000:00/0000:00:1b.0
    SysFS BusID: 0000:00:1b.0
    Model: "Intel Wildcat Point-LP High Definition Audio Controller"
    Device: pci 0x9ca0 "Wildcat Point-LP High Definition Audio Controller"
    Revision: 0x03
    Memory Range: 0xf7418000-0xf741bfff (rw,non-prefetchable)
    IRQ: 49 (349 events)
    Module Alias: "pci:v00008086d00009CA0sv00001028sd00000665bc04sc0 3i00"
    Driver Info #0:
    but;
    pactl list sources
    Verbindungsfehler: Verbindung verweigert
    pa_context_new() fehlgeschlagen: Verbindung verweigert
    Any suggestions?? I'd be thankful.
    Update; same pulseaudio output as posted above. Reinstalling it doesn't work.
  9. Back To Top    #9
    Esteemed Member acheron's Avatar
    Join Date
    May 2016
    Location
    UK
    Posts
    527
    Threads
    19
    Local Date
    Jan 10th 2018
    Local Time
    12:20 PM
    https://bugs.launchpad.net/ubuntu/+source/pulseaudio/+bug/1720519
    https://bugs.launchpad.net/ubuntu/+source/pulseaudio/+bug/1716092
    and have seen another comment that:
    Okay, editing /etc/pulse/default.pa and commenting the last 3 lines …
    ###.ifexists module-switch-on-connect.so …
    ###load-module module-switch-on-connect …
    ###.endif
    seems to solve the issue.
    and
    https://bugs.kde.org/show_bug.cgi?id=384997
    So uptream bug in pulseaudio if that is correct
    On #kubuntu-devel & #kubuntu on irc.freenode.net - IRC Nick: acheronuk - Launchpad ID: click
  10. Back To Top    #10
    Join Date
    Oct 2010
    Location
    Posts
    19
    Threads
    4
    Local Date
    Jan 10th 2018
    Local Time
    07:20 PM
    I can confirm, that commenting mentioned lines in /etc/pulse/default.pa fixed problem on my ThinkPad W520.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
