Wireless dropping out but not disconnecting
    Hey all
    I have had an issue with my laptop's wireless dropping out when I'm doing anything download heavy, it does not actually disconnect just comes to a stand still and web pages etc fail to load.
    I don't really know what information you need from me but the laptop is an ASUS X550JX.
    Thanks
    what does lspci give?
      00:00.0 Host bridge: Intel Corporation Crystal Well DRAM Controller (rev 08)
      00:01.0 PCI bridge: Intel Corporation Crystal Well PCI Express x16 Controller (rev 08)
      00:02.0 VGA compatible controller: Intel Corporation Crystal Well Integrated Graphics Controller (rev 08)
      00:03.0 Audio device: Intel Corporation Crystal Well HD Audio Controller (rev 08)
      00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
      00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
      00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
      00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5)
      00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
      00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d5)
      00:1f.0 ISA bridge: Intel Corporation HM86 Express LPC Controller (rev 05)
      00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
      00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
      01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 950M] (rev ff)
      03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821AE 802.11ac PCIe Wireless Network Adapter
      04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411B PCI Express Card Reader (rev 01)
      04:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
        You are probably running the rtl8821ae driver.
        :~$ modinfo rtl8821ae
        filename:       /lib/modules/4.8.0-42-generic/kernel/drivers/net/wireless/realtek/rtlwifi/rtl8821ae/rtl8821ae.ko
        firmware:       rtlwifi/rtl8821aefw.bin
        description:    Realtek 8821ae 802.11ac PCI wireless
        license:        GPL
        author:         Realtek WlanFAE <wlanfae@realtek.com>
        srcversion:     3205DD813E27A789613A4C3
        alias:          pci:v000010ECd00008821sv*sd*bc*sc*i*
        alias:          pci:v000010ECd00008812sv*sd*bc*sc*i*
        depends:        rtlwifi,rtl_pci,btcoexist,mac80211
        intree:         Y
        vermagic:       4.8.0-42-generic SMP mod_unload modversions
        parm:           swenc:Set to 1 for software crypto (default 0)  (bool)
        parm:           ips:Set to 0 to not use link power save (default 1)  (bool)
        parm:           swlps:Set to 1 to use SW control power save (default 0)  (bool)
        parm:           fwlps:Set to 1 to use FW control power save (default 1)  (bool)
        parm:           msi:Set to 1 to use MSI interrupts mode (default 1)  (bool)
        parm:           debug:Set debug level (0-5) (default 0) (int)
        parm:           disable_watchdog:Set to 1 to disable the watchdog (default 0)  (bool)
        parm:           int_clear:Set to 0 to disable interrupt clear before set (default 1)  (bool)
        The items labeled "parm" are parameters you can set.
        As root create a file called 'rtl8821ae.conf" in /etc/modprobe.d/" and add the following
        options rtl8821ae ips=0
        options rtl8821ae fwlps=0
        options rtl8821ae msi=0
        options rt8821ae int_clear=0
        Then restart the network service using systemctl or log out and log back in.
          I am having the same problem as well as wireless timing out randomly.
          Tried the above but no change.
          lspci;
          00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
          00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
          00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
          00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
          00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
          00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
          00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
          00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b5)
          00:1c.2 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 (rev b5)
          00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
          00:1f.0 ISA bridge: Intel Corporation HM65 Express Chipset Family LPC Controller (rev 05)
          00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 05)
          00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
          01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series] (rev ff)
          07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
          0d:00.0 Network controller: Ralink corp. RT5390 [802.11 b/g/n 1T1R G-band PCI Express Single Chip]
          13:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5209 PCI Express Card Reader (rev 01)
          4 GB Ram
          Kubuntu 18.10
            is it just wireless? did you try the wired connection?
            community is what will save us
              HI
              no, don't have a wire connection. I use my mobile phone as a hot spot. It has unlimited 4G+ connection with an average of download 30 Mbps ans upload of average 25 Mbps.
              4 GB Ram
              Kubuntu 18.10
                firstly, just a reminder:
                Be aware that your tethering allowance isn't the same as your data plan. For instance, T-Mobile's unlimited data plans come with a 5GB tethering allowance. You can use as much data as you want on your phone, but once you attach a laptop, it's 5GB for the month.
                if that's not your case, enter the command nmcli monitor, then start downloading, wait for it to hang, and post the output from the console, if any.
                if there's nothing, post the output of nmcli connection.
                  I'm having exactly the same problem. I created the rtl8821ae.conf in /etc/modprobe.d/ and added the 4 options listed.
                  I then rebooted and I'm still having connectivity issues.
                  I ran nmcli monitor and nmcli connection
                  here are the outputs:
                  donald@sound-X:~$ lspci
                  00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1576
                  00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Carrizo (rev c4)
                  00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Kabini HDMI/DP Audio
                  00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 157b
                  00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 157c
                  00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 157c
                  00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 157b
                  00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 157c
                  00:08.0 Encryption controller: Advanced Micro Devices, Inc. [AMD] Device 1578
                  00:09.0 Host bridge: Advanced Micro Devices, Inc.
                  [AMD] Device 157d
                  00:09.2 Audio device: Advanced Micro Devices, Inc. [AMD] Device 157a
                  00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 20)
                  00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 49)
                  00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 49)
                  00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 4a)
                  00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
                  00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1570
                  00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1571
                  00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1572
                  00:18.3 Host bridge: Advanced Micro Devices, Inc.
                  [AMD] Device 1573
                  00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1574
                  00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1575
                  01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
                  02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821AE 802.11ac PCIe Wireless Network Adapter
                  03:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Bonaire XT [Radeon R9 M280X] (rev ff)
                  donald@sound-X:~$ modinfo rtl8821ae
                  filename:       /lib/modules/4.10.0-33-generic/kernel/drivers/net/wireless/realtek/rtlwifi/rtl8821ae/rtl8821ae.ko
                  license:        GPL
                  srcversion:     B44D8007FC715E99771FA11
                  vermagic:       4.10.0-33-generic SMP mod_unload
                  (bool)
                  (bool)
                  (bool)
                  (bool)
                  (bool)
                  (bool)
                  (bool)
                  donald@sound-X:~$ cat /etc/modprobe.d/rtl8821ae.conf
                  options int_clear=0
                  a very interesting thing did happen, though:
                  donald@sound-X:~$ sudo modprobe -r rtl8821ae && sudo modprobe rtl8821ae
                  [sudo] password for donald:
                  libkmod:  ERROR ../libkmod/libkmod-config.c:635 kmod_config_parse:  /etc/modprobe.d/rtl8821ae.conf line 4: ignoring bad line starting with  'options'
                  here's the nmcli stuff...
                  donald@sound-X:~$ nmcli monitor
                  wlp2s0: device removed
                  Connectivity is now 'none'
                  There's no primary connection
                  Networkmanager is now in the 'disconnected' state
                  wlan0: device created
                  wlan0: unmanaged
                  wlp2s0: unavailable
                  wlp2s0: disconnected
                  Networkmanager is now in the 'connecting' state
                  wlp2s0: connecting (prepare)
                  wlp2s0: using connection 'soundX'
                  wlp2s0: connecting (need authentication)
                  soundX: connection profile changed
                  wlp2s0: connecting (configuring)
                  wlp2s0: connecting (getting IP configuration)
                  Connectivity is now 'full'
                  'soundX' is now the primary connection
                  Networkmanager is now in the 'connected' state
                  wlp2s0: connecting (starting secondary connections)
                  donald@sound-X:~$ nmcli connection
                  NAME                UUID                                  TYPE             DEVICE
                  soundX              839f533d-4bd4-4572-88c2-f962da222637  802-11-wireless  wlp2s0
                  Wired connection 1  11545203-a716-3380-a34e-050f5e0199e9  802-3-ethernet   --
                  weekend             c72f0ba5-e0a6-4a9f-9afc-88a0d49bf75b  802-11-wireless  --
                    You are missing the device driver name in the fourth line of /etc/modprobe.d/rtl8821ae.conf
                    options int_clear=0
                      how do I build that device driver name? Or how do I remedy that?
                      ...duh...I couldn't see the forest through the trees...
                      options rtl8821ae int_clear=0
                        Been there, done that!
                          now I'll test it for a couple of days to see if I'm having better luck...
                            My /etc/modprobe.d/rtl8821ae.conf looks like the above.
                            where do I put the device name?
                            lspci gives:
                            nmcli monitor gives nothing.
                            nmcli connection gives:
                            fintan@fintan-ws1:~$ nmcli connection
                            AndroidAP 6c8a1b62-a349-4244-a80d-1ae607d5f9db 802-11-wireless wlo1
                            Thank you!
                            4 GB Ram
                            Kubuntu 18.10
                              lspci gives:
                              Thank you!
                              Your wireless chip is an rt5390
                              I don't know if there is a driver for it.
                              Does "modinfo rt5390" give anything?
