Results 1 to 6 of 6
Thread: Long-standing cosmetic issue/s?
  1. Back To Top    #1
    Senior Member Fester Bestertester's Avatar
    Join Date
    Feb 2014
    Location
    NZ
    Posts
    224
    Threads
    57
    Local Date
    Jan 10th 2018
    Local Time
    11:46 PM
    G'day from 'up over'!
    Just upgraded 16.10 to 17.04. No hiccups, overall seamless and utterly satisfactory. But... reboot, and the login prompt continues to display my 'Real Name' from original install back in the dim dark past. I would suggest a far more satisfying and 'human' greeting would be my account name, or a pseudonym?
    Also, probably a 'newbie' question: how to enable a 'guest' login (non-admin and sudo locked out/disabled)? I'd like to be able to have grandkids get used to using Linux without destroying my system :)
  2. Back To Top    #2
    Esteemed Member Rod J's Avatar
    Join Date
    Jan 2012
    Location
    New Zealand
    Posts
    528
    Threads
    11
    Local Date
    Jan 10th 2018
    Local Time
    11:46 PM
    Quote Originally Posted by Fester Bestertester View Post
    Hi Fester Bestertester from a fellow NZ'er!
    To create a "Guest" login In my K16.04 system I would go to System Settings, Account Details, User Manager then create a "New User" login called "Guest" and make sure the "Administrator" box is left unticked. Also, make sure the grandkids don't know your own password. I think that would effectively limit what damage they could do ... maybe
    In my K14.04 system it's a little different in that the Login Screen section in the System Settings has an option to allow a guest login ... can't see a similar option in K16.04 here. I haven't used Plasma 5 enough to be sure about that though.
    In answer to the first query about user name change I think you should be able to change your "Real Name" in your own account details in the User Manager too.
    Desktop PC: Intel Core-i5-4670 3.40Ghz, 16Gb Crucial ram, Asus H97-Plus MB, 128Gb Crucial SSD + 2Tb Seagate Barracuda 7200.14 HDD running Kubuntu 14.04 LTS 64Bit and Mint KDE 18.02 64Bit (on SSD).
    Laptop: HP EliteBook 8460p Core-i5-2540M, 4Gb mem, 500Gb HDD, running Mint KDE 18.02 (until Kubuntu 18.04 arrives).
  3. Back To Top    #3
    Emergent AI Rog131's Avatar
    Join Date
    Nov 2005
    Posts
    4,336
    Threads
    124
    Local Date
    Jan 10th 2018
    Local Time
    10:46 AM
    SDDM 'names'
    The KDE SDDM breeze greeter is showing the real name if set. If not then it will show the username - /usr/share/sddm/themes/breeze/components/UserList.qml:
            var displayName = model.realName || model.name
    KDE System Settings > Account Details > User Manager
    The User Manager can add but also remove the 'Real Names*
    Guest
    SDDM issues - Guest login #388: https://github.com/sddm/sddm/issues/388
    -> https://bbs.archlinux.org/viewtopic.php?id=192891
    At here, adding:
    /usr/share/sddm/scripts/Xsetup
    /usr/share/sddm/scripts/Xstop
    /root/scripts/guest-account
    Note #1 Ubuntu package: http://packages.ubuntu.com/search?se...zesty&arch=any has the guest-account.sh ../lightdm-1.22.0/debian/guest-account.sh
    Note #2 Setting the '--uid 1024' : https://askubuntu.com/questions/6991...guest-accounts
    Reboot...
    ... and there is a Guest account (password: guest).
    More:
    Avatars: https://forum.kde.org/viewtopic.php?...art=15#p374337
    Keyboard localisation on login screen (SDDM): https://forum.kde.org/viewtopic.php?f=309&t=138783
    What locale settings sddm respects?: https://www.bountysource.com/issues/...-sddm-respects
    Before you edit, BACKUP !
    Why there are dead links ?
    2. Thread: Lost Information
  4. Back To Top    #4
    Ascendant GreyGeek's Avatar
    Join Date
    Feb 2009
    Location
    Lincoln, NE
    Posts
    13,723
    Threads
    978
    Local Date
    Jan 10th 2018
    Local Time
    04:46 AM
    I've done what Rod J suggested and it works great. (Adding Rog131's flourishes would be great!)
    Kids will try anything and more than likely they will use Dolphin to destroy EVERYTHING in and below /home/guest!
    No problem. Just delete guest and then re-add it. Let them re-make their desktop icons and browser links, etc..., as payment for the mischief!
    There is no truth in the news, and no news in the truth.
  5. Back To Top    #5
    Join Date
    Feb 2014
    Location
    NZ
    Posts
    224
    Threads
    57
    Local Date
    Jan 10th 2018
    Local Time
    11:46 PM
    Hi Rod J
    para.1: Good, but (essential) password "guest", though desirable, too short. *8 chars min.
    para.2: K17.04 like 16.04 (and 10).
    para.3: Rog131's answer below gave a hint that works. See my reply there.
  6. Back To Top    #6
    Join Date
    Feb 2014
    Location
    NZ
    Posts
    224
    Threads
    57
    Local Date
    Jan 10th 2018
    Local Time
    11:46 PM
    Quote Originally Posted by Rog131 View Post
    SDDM 'names'
    This did the trick:
           var displayName = model.name || model.realName
    Thanks!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
