Results 1 to 6 of 6
Thread: Need help in WiFI connection
  1. Back To Top    #1
    Newbie
    Join Date
    Aug 2016
    Posts
    2
    Threads
    1
    Local Date
    Jan 6th 2018
    Local Time
    09:54 AM
    Exclamation Need help in WiFI connection
    I am newbie in Kubuntu. Today I have installed Kubuntu Latest LTS build. Everything is working fine after installation but Some problems keep irritating me after roaming around. They are:
    1. If my laptop goes into sleep mode or I have rebooted laptop, every time I need to provide my wifi password. It can't remember the provided password.
    2. I can't download any software from the software centre. It doesn't shows any software like if I search for " VLC". though my internet is working fine.
    3. If I disable "Power Management" , after reboot it can't remember my setting. it re enabled automatically.
    Please help regarding all this problems anyone. Please provide step by step instructions.
    Thanks
    Waiting for reply!!
    :D
  2. Back To Top    #2
    Ascendant GreyGeek's Avatar
    Join Date
    Feb 2009
    Location
    Lincoln, NE
    Posts
    13,710
    Threads
    978
    Local Date
    Jan 5th 2018
    Local Time
    10:24 PM
    Quote Originally Posted by ceasar47 View Post
    Right mouse on the Internet Icon in the System Tray and left click on "Configure Network Connections".
    Select your wifi connection and click the "Edit" tool bar option. Select the "Wi-Fi Security" tab. You will see something like this:
    Click image for larger version.
    Enter your password in the Password text box (Mine contains my concealed password.) and click the OK button.
    That pkg is a work in progress. Open a Konsole and enter:
    sudo apt update
    sudo apt install muon
    When it is done look for Muon Package Manager under the System menu. It's what you want to use.
    I assume you are using Power Management in SystemSetttings. You cannot "disable" Power Management, but you can edit the various settings on "AC Power", "Battery" and "Low Battery", and apply the changes. You'll be asked for your password.
    There is no truth in the news, and no news in the truth.
  3. Back To Top    #3
    Newbie
    Join Date
    Aug 2016
    Posts
    2
    Threads
    1
    Local Date
    Jan 6th 2018
    Local Time
    09:54 AM
    Thanks for your quick help regarding my issues.....
    All worked successfully!!
    Another query : How to up to date my system with the latest updates from Kubuntu using Konsole. Cause the UI of "Updates" is not showing how much percentage of the update downloaded or completed.
    GreyGeek
    Thanks again......
  4. Back To Top    #4
    Join Date
    Feb 2009
    Location
    Lincoln, NE
    Posts
    13,710
    Threads
    978
    Local Date
    Jan 5th 2018
    Local Time
    10:24 PM
    Open a Konsole and type:
    sudo apt-get update
    then follow that with
    sudo apt-get dist-upgrade
  5. Back To Top    #5
    Kubuntu as Second Language
    Join Date
    Apr 2008
    Location
    Auckland, New Zealand
    Posts
    1,025
    Threads
    43
    Local Date
    Jan 6th 2018
    Local Time
    05:24 PM
    ... is not showing how much percentage of the update downloaded or completed...
    GreyGeek's commands using apt-get certainly work, but the apt commands show slightly more info about progress, and more colourfully:
    sudo apt update
    sudo apt full-upgrade
  6. Back To Top    #6
    Join Date
    Feb 2009
    Location
    Lincoln, NE
    Posts
    13,710
    Threads
    978
    Local Date
    Jan 5th 2018
    Local Time
    10:24 PM
    Quote Originally Posted by jlittle View Post
    sudo apt update
    True.
    In my case old habits are hard to break.
    I can't remember the apt parameters and I'm too lazy to look them up.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
