Long shut down
    Long shut down
    Hello everyone this is my first time posting here so I hope this is the correct forum for this
    I just installed Kubuntu 16.04 but I notice every time I shut my machine down I get this message
    Message I receive:
    a stop job is running for Session c13 of user XX (Xs / 1min 30s)
    It takes some time to shut down is there anyway to correct this problem
    Thanks so much
    The short answer is 'no'. I have the same issue and have reported it, but not gotten what I concider a good response, specifically with regards to how to prevent it. That said, if you log out of the Desktop session first, and then when you are back to the Login screen, click on the Poweroff icon, you will not experience this issue. It's what I do now.
    Slava Ukraini! πŸ‡ΊπŸ‡¦
      This is my first time using Kubuntu but I do have many other distributions on other machines and never had this issue I've seen some others complaining about this same issue but have not seen a fix for it.
      Thanks so much
        Reduce the waiting ... give the permission to kill
        Arch - Problems with latest systemd 226-3: https://bbs.archlinux.org/viewtopic.php?id=203112
        -> Reduce the wait time: https://bbs.archlinux.org/viewtopic....69285#p1569285
        Give systemd the permission to kill ( default with the later versions)
        -> Debian bug reports - systemd kill background processes after user logs out: https://bugs.debian.org/cgi-bin/bugr...cgi?bug=825394
        From the changelog of systemd version 230:
        systemd-logind will now by default terminate user processes that are
        part of the user session scope unit (session-XX.scope) when the user
        logs out.
        /etc/systemd/logind.conf:
        KillUserProcesses=yes
        Before you edit, BACKUP !
        Why there are dead links ?
        2. Thread: Lost Information
          KillUserProcesses=yes didn't resolve the issue for me; I tried it. In fact, that 'solution' was suggested when I reported the issue. For some it 'apparently' works, but not for all.
          But, as I stated, doing a Desktop session logout first and then shutting down from the login greeter screen does work (for me). I reported that also.
            Yes your suggestion work but only as a temporary fix there should be a fix for this issue
            Thanks
              Really, performing a user session logout and then shutting down, is a 'better' practice. I don't mind the extra step.
                Yes I know what you're saying and thanks
                  Actually, that's true for a NOT well-mannered OS.
                  Intel i7 11th Gen 16GB 1TB
                    ...and with
                    Bug 363851 - "A stop job is running for Session 1 of user neon" during shutdown: https://bugs.kde.org/show_bug.cgi?id=363851
                    28 & 29 https://bugs.kde.org/show_bug.cgi?id=363851#c28
                    Harald Sitter 2016-08-09 08:25:33 UTC
                    I think this should be solved in dev editions within the hour and for user edition some time this week.
                    http://packaging.neon.kde.org/cgit/n...a2ef35a31430b6
                    Harald Sitter 2016-08-09 08:45:40 UTC
                    nevermind, still broken. won't be solved until plasma learns to clean up and our software learns to not crash in destructors.
                      Well even that is a bit out of date, as Harold and Jonathan are currently still trying to thrash this out and fix on #kde-neon on freenode irc.
