can't mount android device
    hello there,
    I'm running Kubuntu 16.04 on an Asus ZenBook UX301LA (please see below). I also have two android devices (Asus ZenPad + Asus ZenFone).
    when I connect either device, Dolphin shows the following message:
    The process for the mtp protocol died unexpectedly.
    (occasionally the message is slightly different: Could not read. Reason: Could not claim the USB device).
    I found a few posts about having to install kio-mtp (which - according to Synaptics - is already installed: version 0.75 + git 20140304) but no other hint there might be a different solution.
    can you please help? thanks.
    here're some info about my system (what I could gather):
    - DISTRIB_RELEASE=16.04;
    - sorry "Alt+F2 then type dolphin then click on Help > About KDE" doesn't give any useful info about KDE...(that I can see..);
    - ~$ apt-cache show grub | grep ersion
    Version: 0.97-29ubuntu68
    Description-en_GB: GRand Unified Bootloader (Legacy version);
    ~$ lscpu
    Architecture: x86_64
    CPU op-mode(s): 32-bit, 64-bit
    Byte Order: Little Endian
    CPU(s): 4
    On-line CPU(s) list: 0-3
    Thread(s) per core: 2
    Core(s) per socket: 2
    Socket(s): 1
    NUMA node(s): 1
    Vendor ID: GenuineIntel
    CPU family: 6
    Model: 69
    Model name: Intel(R) Core(TM) i5-4200U CPU @ 1.60G
    Stepping: 1
    CPU MHz: 1098.429
    CPU max MHz: 2600.0000
    CPU min MHz: 800.0000
    BogoMIPS: 4588.98
    Virtualisation: VT-x
    L1d cache: 32K
    L1i cache: 32K
    L2 cache: 256K
    L3 cache: 3072K
    NUMA node0 CPU(s): 0-3
    Flags: fpu vme de pse tsc msr pae mce cx8 api
    pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscal
    tant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonsto
    ni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma
    sse4_2 movbe popcnt tsc_deadline_timer aes xsave avx f16c rd
    adow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2
    veopt dtherm ida arat pln pts
    ~$ lspci | grep aphic
    00:02.0 VGA compatible controller: Intel Corporation Haswell-
    troller (rev 09)
    I tried switching to USB>PTP (instead of MTP) on my android device: I can read but cannot transfer files Kubuntu>Android.
      update: reboot + connect android device again. This time I get the following error:
      The file or folder udi=/org/kde/solid/udev/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/ does not exist.
        after switching back to MTP mode on the android device, that is
          On my desktop MTP android transfer will not work or fails part way through, no matter what I try.
          On my laptop it works flawlessly with same config.
            MTP is inherently dodgy, perhaps partly because it's a Microsoft protocol. Have you tried using KDE Connect? One end already in your Xenial, the other free in Google play.
