With a bit of creative work, one can solve this problem. Take a look at the graph:
kubuntu-restricted-extras
---depends
------kubuntu-restricted-addons
---------recommends
------------flashplugin-installer
------------multimedia stuff
---recommends
------Microsoft fonts
------unRAR
To obtain everything these packages provide, remove the included Flash, and make the lightbulb go away:
sudo apt-get install kubuntu-restricted-extras
sudo apt-mark manual gstreamer* libavcodec-extra-53 libmp3lame0 unrar ttf-mscorefonts-installer lame libk3b6-extracodecs libdvdread4
sudo apt-get purge flashplugin-installer kubuntu-restricted-addons kubuntu-restricted-extras
The first command installs the metapackages, which in turn install the recommendations. The second command marks the recommendations as manually-installed. The third command removes the metapackages. Removing a reverse dependent of a recommend doesn't remove the recommend, but it does place the recommend at danger of being removed with an errant apt-get autoremove. By marking the recommends as manual (second command), we avoid that potential future risk.
Of course, you can avoid this work by simply manually installing the recommends and never installing the restricted metapackages at all:
sudo apt-get install gstreamer0.10-plugins-* gstreamer0.10-ffmpeg gstreamer0.10-fluendo-mp3 libavcodec-extra-53 libmp3lame0 unrar ttf-mscorefonts-installer lame libk3b6-extracodecs libdvdread4
Then, enable the Partner repository and get Flash from there:
sudo apt-get update && sudo apt-get install adobe-flashplugin adobe-flash-properties-kde
I know that Aptitude isn't very popular around here. But for the task I've described here -- picking and choosing recommends and removing metapackages -- Aptitude beats everything else. Just thought I'd toss that one out there
