Need help for Netgear WNDA3100 wireless adapter
    Trying to install the WNDA3100 wireless adapter driver using this ubuntu forum thread:
    http://ubuntuforums.org/showthread.php?t=1383708
    It looked promising at first; I installed wine, used wine to "install" the driver,
    but came to a step where it calls for using System/Administration/Windows Wireless Drivers.
    That utility is supposed to be pointed to the file bcmwlhigh5.inf -- the file was indeed
    written, but I'm not sure where to go from here. Is there a kubuntu utility similar to
    the above mentioned ubuntu tool? Or some other way to install this driver?
    kubuntu 10.04
    $ uname -a
    Linux greentux 2.6.32-33-generic #72-Ubuntu SMP Fri Jul 29 21:07:13 UTC 2011 x86_64 GNU/Linux
    $ lspci
    00:00.0 Host bridge: Advanced Micro Devices [AMD] RS780 Host Bridge
    00:01.0 PCI bridge: ASUSTeK Computer Inc. RS880 PCI to PCI bridge (int gfx)
    00:05.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 1)
    00:06.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 2)
    00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [IDE mode]
    00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller
    00:12.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller
    00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
    00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller
    00:13.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller
    00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
    00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 3a)
    00:14.1 IDE interface: ATI Technologies Inc SB700/SB800 IDE Controller
    00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
    00:14.3 ISA bridge: ATI Technologies Inc SB700/SB800 LPC host controller
    00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge
    00:14.5 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI2 Controller
    00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
    00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
    00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
    00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
    01:05.0 VGA compatible controller: ATI Technologies Inc Radeon HD 3200 Graphics
    01:05.1 Audio device: ATI Technologies Inc RS780 Azalia controller
    02:00.0 FireWire (IEEE 1394): JMicron Technology Corp. IEEE 1394 Host Controller
    03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
    04:07.0 Ethernet controller: ADMtek NC100 Network Everywhere Fast Ethernet 10/100 (rev 11)
    $ lsusb
    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 004 Device 002: ID 045e:00db Microsoft Corp. Natural Ergonomic Keyboard 4000 V1.0
    Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 002 Device 004: ID 0846:9011 NetGear, Inc.
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Thanks,
    /dennis
