kernel 3.9 and sound
    I installed the kernel 3.9 from here:
    http://kernel.ubuntu.com/~kernel-ppa/mainline/
    After rebooting sound is gone.
    I also noticed that the image-extras package was not there anymore.
    any ideas?
    4 GB Ram
    Kubuntu 18.10
    How - Logs - SoundTroubleshooting - At here
    How and what did you install ?
    What was the output ?
    What the logs are telling ? dmesg ?
    image-extras ?
    With the 3.8.0-19 there are available:
    linux-headers
    linux-image-extra
    linux-image
    With the 3.9 there are available
    linux-headers
    linux-image
    Have you tried the sound troubleshooting ?
    https://help.ubuntu.com/community/SoundTroubleshooting
    https://help.ubuntu.com/community/So...otingProcedure
    At here (headers needed for the dkms->fglrx):
    Log of sudo apt-get install linux-image-3.9.0-030900-generic linux-headers-3.9.0-030900-generic
    Wed May 1 17:33:57 2013
    linux-headers-3.9.0-030900 linux-headers-3.9.0-030900-generic
    0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
    Found linux image: /boot/vmlinuz-3.9.0-030900-generic
    Found initrd image: /boot/initrd.img-3.9.0-030900-generic
    Found linux image: /boot/vmlinuz-3.8.0-19-generic
    Found initrd image: /boot/initrd.img-3.8.0-19-generic
    Setting up linux-headers-3.9.0-030900 (3.9.0-030900.201304291257) ...
    Setting up linux-headers-3.9.0-030900-generic (3.9.0-030900.201304291257) ...
    Examining /etc/kernel/header_postinst.d.
    run-parts: executing /etc/kernel/header_postinst.d/dkms 3.9.0-030900-generic /boot/vmlinuz-3.9.0-030900-generic
    Rebooting...
    The sound seems to work.
    Version is:
    :~$ uname -a
    Linux fox6r 3.9.0-030900-generic #201304291257 SMP Mon Apr 29 16:58:15 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
    Fglrx is working:
    :~$ fglrxinfo
    display: :0 screen: 0
    OpenGL vendor string: Advanced Micro Devices, Inc.
    OpenGL renderer string: AMD Radeon HD 6800 Series
    OpenGL version string: 4.2.12217 Compatibility Profile Context 12.104
    linux-image-extra-3.8.0-19-generic is there:
    :~$ apt-cache policy linux-image-extra-3.8.0-19-generic
    linux-image-extra-3.8.0-19-generic:
    Installed: 3.8.0-19.29
    Candidate: 3.8.0-19.29
    Version table:
    *** 3.8.0-19.29 0
    500 http://fi.archive.ubuntu.com/ubuntu/ raring/main amd64 Packages
    100 /var/lib/dpkg/status
    Before you edit, BACKUP !
    Why there are dead links ?
    2. Thread: Lost Information
      i lose HDMI output if im using the 3.8.0-18 and 3.8.0.19 kernels. my machine reverts to onboard sound ports. it seams like i lose sound , i wonder could you be having a similar issue where you lose only hdmi sound
      (top of thread: thread tools)
        I think the 3.9 kernels are a little wonky. When I tried the one dated 29 April, I get this error upon boot:
        Failed to alloc lowmem for boot params
        Then I tried the one under "current" (which was yesterday, 30 April). It boots, but the nVidia drivers won't compile. The make.log gripes:
        FATAL: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol 'system_wq'
        This is with 319.12 from Xorg-Edgers. Oddly, the driver compiles fine under the previous 3.9 kernel, and also under 3.8 Ubuntu and 3.8 Liquorix.
          The Ubuntu +1 ( http://ubuntuforums.org/forumdisplay.php?f=427 ) has a thread: 3.9 kernel and broadcom drivers ( http://ubuntuforums.org/showthread.php?t=2140858 )
            HI guys. I just dowloaded the packages from here:
            and installed with gdebi.
            This has always worked until now.
            I'll have to reboot to 3.9 and get back here later.
            Edit: rebooted to 3.9
            uname -a
            Linux fintanws1 3.9.0-030900-generic #201304291257 SMP Mon Apr 29 16:58:15 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
            dmesg is in the attch.
            I'll have a look at all those links later today and get back to you. Thankx
            Don't have x-edgers installed (Yet)
            4 GB Ram
            Kubuntu 18.10
              To me it seems that the system is detecting the audio right:
              [ 12.247530] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
              [ 12.247664] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
              [ 12.247799] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
              There are audio problems with the 3.9 kernel: http://ubuntuforums.org/showthread.php?t=2122068 -> http://ubuntuforums.org/showthread.p...4#post12633424
